Full Version: Newbie ? - Installing
I downloaded the folder for 4.00 RC1 into my addons folder and restarted XBMC but don't see Rapier as an option when changing skins. What do I do wrong? Readme.txt doesn't have any installation instructions as noted at http://tvnca.deviantart.com/#/d29r42w ... I'm on Win7
Thanks,
Andrew
Install it to c:\Users\Your_Username\AppData\Roaming\XBMC\addons\skin.rapier.xbox\
I think that's where it's supposed to go if you set xbmc to use the appdata folder at install time. I know it's working for me.
