2005-04-11, 20:15
xbmc v1.0 build 9-24-04 was working fine, but was getting a bit stale, so i decided to update.
completely deleted old install folder under f:\apps (running evox).
deleted all cache files in x: y: z: partitions.
deleted 0face008 in e:udata and e:tdata.
(forgive me if i'm getting a few of the names wrong, i'm at work and going from memory)
ftp'd new xbmc v1.1 build 4-9-05 to f:\apps
evox sees the new install, as xbox media center appears under the apps menu, and attempts to load. screen goes blank, hard drive reads for a second or two, then drops back to the evox apps menu.
i have the xbmc .xml config file (forget the name) set to an error level of 0, but i can find no instance of a log file to see what the hell is going wrong.
as i am not running xbmc as my dash, i made no other mods to the .xml config file (left home-/home as it is).
my thoughts: do i have a bad build? do i need to change something in the skins folder? (i seem to remember on the v1.0 build i had to change something from pal to ntsc, or something)
help!!
help!!
