Full Version: Aeon Nox Config?? I'm confused
OK, So I normally use standard ol' MCE and Media Browser to do my thing, but I want to try and return to XBMC.
I've setup a test directory with some movies so I can learn how to do things before moving onto my HTPC.
I love the look of Aeon Nox, but I'm a bit confused as to the configuration portion. I see screen shots galore that are all polished and great, but I am unsure how to get there. This shot in particular is where i want to get to:
http://wiki.xbmc.org/index.php?title=Fil...Movies.jpg
Any pointers you can provide would be great. I'm happy to provide any additional info you might need. Thanks!
You need to add a movie folder and select the movie scraper, like imdb/ moviedb. Once that is done, go into movies and use the keyboard to left arrow a few times and the view type menu will popup.
