*** EDIT ***: Thought that this problem I originally wrote about below was on my end, but in light of the fact that forum.xbmc.org is really slow for me today, and there seems to be a broken nightly on only one mirror, I'm wondering if there's some larger issue with xbmc.org?
So, woke up this beautiful morning, yawned, decided to upgrade to latest nightly as always. And this happened.
(Reading database ... 3487 files and directories currently installed.)
Preparing to replace org.xbmc.xbmc-atv2 10.0-9 (using xbmc-20111021-79cceb5-master-atv2.deb) ...
Unpacking replacement org.xbmc.xbmc-atv2 ...
dpkg-deb (subprocess): short read in buffer_copy (failed to write to pipe in copy)
dpkg-deb: subprocess paste returned error exit status 2
dpkg: error processing xbmc-20111021-79cceb5-master-atv2.deb (--install):
short read in buffer_copy (backend dpkg-deb during `./Applications/XBMC.frappliance/Frameworks/libsmbclient.dylib.0')
chown: cannot access `/Applications/XBMC.frappliance': No such file or directory
Errors were encountered while processing:
No such file or directory? You're kidding? Nope, not kidding--went and had a look, and XBMC.frappliance is no longer there. Hmmm.
Good morning!
I guess the only thing to do at this point is back up my /var/mobile folder (the contents of THAT are still there, at least) and reinstall from scratch?
Looks like your deb is broken ... no need to rejb ... just retry the download and install again ...
oh.
LOL!! Thanks Memphiz...I was panicking there a bit
I'll redownload and try again.
Hmmm, interesting. Is there a mirroring issue? Looks like the latest build, from a few hours ago, is only on one mirror server, which is currently hung up completely for me.
http://mirrors.xbmc.org/nightlies/darwin...mirrorlist
*** EDIT ***:
And...now everything's fine
never mind folks, move along, nothing to see here!
Hmmm. This just happened to me again ("cannot access /Applications/XBMC.frappliance: no directory found"). There's nothing in /var/mobile/Applications. But unlike last time, this time I tried again and installed the Nov 28 nightly (successfully), and it still doesn't work--I see XBMC in the FrontRow screen, but when I click it, the Apple TV just reboots. And there's still nothing in /Applications. Tried again with Dec 1 nightly, same thing.
Yikes! Any ideas?
14:57:23 T:106385408 NOTICE: -----------------------------------------------------------------------
14:57:24 T:106385408 NOTICE: Starting XBMC, Platform: Darwin iOS (11.0.0 AppleTV2,1). Built on Dec 1 2011 (Git:20111129-b67a2a4)
14:57:24 T:106385408 NOTICE: special://xbmc/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
14:57:24 T:106385408 NOTICE: special://xbmcbin/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
14:57:24 T:106385408 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Library/Preferences/XBMC/userdata
14:57:24 T:106385408 NOTICE: special://home/ is mapped to: /var/mobile/Library/Preferences/XBMC
14:57:24 T:106385408 NOTICE: special://temp/ is mapped to: /var/mobile/Library/Preferences/XBMC/temp
14:57:24 T:106385408 NOTICE: special://frameworks/ is mapped to: /var/stash/Applications/XBMC.frappliance/Frameworks
14:57:24 T:106385408 NOTICE: The executable running is: /var/stash/Applications/XBMC.frappliance/XBMC
14:57:24 T:106385408 NOTICE: Log File is located: /var/mobile/Library/Preferences/xbmc.log
14:57:24 T:106385408 NOTICE: -----------------------------------------------------------------------
14:57:24 T:106385408 NOTICE: load settings...
14:57:24 T:106385408 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:57:24 T:106385408 NOTICE: loading special://masterprofile/guisettings.xml
14:57:24 T:106385408 NOTICE: Getting hardware information now...
14:57:24 T:106385408 INFO: Using digital output
14:57:24 T:106385408 INFO: AC3 pass through is enabled
14:57:24 T:106385408 INFO: DTS pass through is enabled
14:57:24 T:106385408 INFO: AAC pass through is disabled
14:57:24 T:106385408 INFO: MP1 pass through is disabled
14:57:24 T:106385408 INFO: MP2 pass through is disabled
14:57:24 T:106385408 INFO: MP3 pass through is disabled
14:57:24 T:106385408 DEBUG: Error: Requested setting (videoscreen.screenmode) was not found. It must be case-sensitive
14:57:24 T:106385408 NOTICE: Checking resolution 12
14:57:24 T:106385408 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:57:24 T:106385408 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
14:57:24 T:106385408 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
14:57:24 T:106385408 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
14:57:24 T:106385408 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
14:57:24 T:106385408 NOTICE: Loaded playercorefactory configuration
14:57:24 T:106385408 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:57:24 T:106385408 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:57:24 T:106385408 NOTICE: No settings file to load to load (special://xbmc/system/advancedsettings.xml)
14:57:24 T:106385408 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
14:57:24 T:106385408 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.211</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_video</name>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_music</name>
</musicdatabase>
<videoextensions>
<add>.html</add>
</videoextensions>
<video>
<playcountminimumpercent>90</playcountminimumpercent>
</video>
<busydialogdelay>20000</busydialogdelay>
<loglevel>1</loglevel>
<network>
<cachemembuffersize>0</cachemembuffersize>
</network>
</advancedsettings>
14:57:24 T:106385408 NOTICE: Log level changed to 1
14:57:24 T:106385408 WARNING: VIDEO database configuration is experimental.
14:57:24 T:106385408 NOTICE: Default DVD Player: dvdplayer
14:57:24 T:106385408 NOTICE: Default Video Player: dvdplayer
14:57:24 T:106385408 NOTICE: Default Audio Player: paplayer
14:57:24 T:106385408 NOTICE: Disabled debug logging due to GUI setting. Level 1.
14:57:24 T:106385408 NOTICE: Loading media sources from special://masterprofile/sources.xml
14:57:24 T:106385408 DEBUG: Setting <default> source to : Music
14:57:24 T:106385408 INFO: creating subdirectories
14:57:24 T:106385408 INFO: userdata folder: special://masterprofile/
14:57:24 T:106385408 INFO: recording folder:
14:57:24 T:106385408 INFO: screenshots folder:
14:57:24 T:106385408 INFO: thumbnails folder: special://masterprofile/Thumbnails
14:57:25 T:106385408 INFO: load language info file: special://xbmc/language/English/langinfo.xml
14:57:25 T:106385408 DEBUG: trying to set locale to en_CA.UTF-8
14:57:25 T:106385408 INFO: global locale set to C
14:57:25 T:106385408 INFO: load language file:special://xbmc/language/English/strings.xml
14:57:25 T:106385408 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-arm-osx.so)
14:57:25 T:106385408 DEBUG: Loading: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/system/libcpluff-arm-osx.so
14:57:25 T:106385408 ERROR: SQL: The database disk image is malformed
Query: SELECT idVersion FROM version
Yep, I see that...but I can connect to my NAS-based SQL (XBMC video/music) databases from elsewhere and access them and browse them without any problems...and I didn't make any changes to anything on that end. Odd! Not quite sure where to go from here to troubleshoot that.
Well, this is interesting.
Not knowing what else to do, I blew away my XBMC video/music SQL databases on my NAS (after exporting them as a backup first) and then recreated the databases. When I try to import the backed up data into the newly created databases in phpMyAdmin, I get errors. For the video database, for instance, I get this:
Error
SQL query: Documentation
-- -------------------------------------------------------- -- -- Table structure for table `episodeview` -- CREATE ALGORITHM=UNDEFINED DEFINER=`xbmc`@`%` SQL SECURITY DEFINER VIEW `xbmc_video`.`episodeview` AS select `xbmc_video`.`episode`.`idEpisode` AS `idEpisode`,`xbmc_video`.`episode`.`idFile` AS `idFile`,`xbmc_video`.`episode`.`c00` AS `c00`,`xbmc_video`.`episode`.`c01` AS `c01`,`xbmc_video`.`episode`.`c02` AS `c02`,`xbmc_video`.`episode`.`c03` AS `c03`,`xbmc_video`.`episode`.`c04` AS `c04`,`xbmc_video`.`episode`.`c05` AS `c05`,`xbmc_video`.`episode`.`c06` AS `c06`,`xbmc_video`.`episode`.`c07` AS `c07`,`xbmc_video`.`episode`.`c08` AS `c08`,`xbmc_video`.`episode`.`c09` AS `c09`,`xbmc_video`.`episode`.`c10` AS `c10`,`xbmc_video`.`episode`.`c11` AS `c11`,`xbmc_video`.`episode`.`c12` AS `c12`,`xbmc_video`.`episode`.`c13` AS `c13`,`xbmc_video`.`episode`.`c14` AS `c14`,`xbmc_video`.`episode`.`c15` AS `c15`,`xbmc_video`.`episode`.`c16` AS `c16`,`xbmc_video`.`episode`.`c17` AS `c17`,[...]
MySQL said: Documentation
#1146 - Table 'xbmc_video.files' doesn't exist
That error occurs while it's trying to create the "episode" table. All tables alphabetically before "episode" are created and populated with data without a problem, but the error above stops the import. I get a similar error occur with the music database: it's another SQL error #1146, except this time it says "Table 'xbmc_music.thumb' doesn't exist". Again some tables are created before it, but that error halts the import.
What in the world
Okay...guys, I know I probably screwed this up somehow on my own, but I could use a hand right about now. Or a hug
I have no idea why my XBMC suddenly went haywire on me. End result: I deleted my XBMC folder from my ATV2 and reinstalled the latest nightly. I also deleted my databases from my NAS and recreated them manually.
Now, when I go into XBMC, it's incredibly unresponsive. And I see why:
http://pastebin.com/8pz4KPW7
...but I don't know what to do about that
I know the SQL database is empty...but what am I supposed to do here?
I just tried deleting the SQL databases again (this is all being done in phpMyAdmin btw) and letting XBMC create them itself via the advancedsettings.xml file. But instead of creating "xbmc_video" and "xbmc_music", it creates "xbmc_video57" and "xbmc_music18". I renamed those to xbmc_video and xbmc_music, rebooted XBMC, and now I have FOUR databases; those two, plus, again, xbmc_video57 and xbmc_music18. Ugh!!
canadave Wrote:Okay...guys, I know I probably screwed this up somehow on my own, but I could use a hand right about now. Or a hug
...but I don't know what to do about that I know the SQL database is empty...but what am I supposed to do here?
Let XBMC create the DBs and don't touch em. the 57 and 18 are the structure versions and are needed. The way DB updates are working on mysql was changed so that it works identically like with sqlite. So everything looks ok - you just keep your hands off, after xbmc did its job creating the db.
Memphiz Wrote:Let XBMC create the DBs and don't touch em. the 57 and 18 are the structure versions and are needed. The way DB updates are working on mysql was changed so that it works identically like with sqlite. So everything looks ok - you just keep your hands off, after xbmc did its job creating the db.
Oh....lol well THAT might explain a few things
So I need to change my advancedsettings.xml so that it points to "xbmc_video57" rather than "xbmc_video", I guess?
Thanks...that was driving me crazy!
Quote:So I need to change my advancedsettings.xml so that it points to "xbmc_video57" rather than "xbmc_video", I guess?
No!!! Don't do that. I am not an expert from my understanding here is how it works.
The DB name you have in advanced settings is used as the prefix for the name of the DB that will be used. It is appeneded with a number that changes with each version of the db.
So on startup it gets the prefix of the db name from advanced settings, then looks for the latest DB schema. Once found it checks if it needs to be updated, if it does, it copys the newest schema you already have and changes the number on the end to the appropriate version. Then it updates the schema it just copied with any needed changes.
So if you change the name in advanced settings to be 'xbmc_video57' the schema name could end up being 'xbmc_video5757'.
Why did they do this? One of the problems use to be when you upgraded to a newer version (nightly for example) it upgraded your dbschema, which will not work with older versions. So if there was an issue, it was next to impossible to rollback. Now you just downgrade xbmc, delete the schema it created and you are back to where you were before.
Please Note that this is just what I pieced together from reading the forum and what not.
jschoen, I think I know what you're thinking of with that, but I don't think that's what's happening here
FWIW, before you replied, I did change my advancedsettings.xml to point to xbmc_video57, and it worked fine.
All advancedsettings.xml does is tell XBMC where to connect to your SQL database. When I let XBMC create the database on my NAS, it created "xbmc_video57" without my needing to. Then, in advancedsettings.xml, I told XBMC to go connect to that database. That seems to have worked perfectly.
Note that I was not using advancedsettings.xml to tell XBMC *what to name* the database; I was just telling it where to connect to the existing database.
My undertanding is if you have
Quote:<videodatabase>
<type>mysql</type>
<host>***.***.***.***</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>SOME_NAME</name>
</videodatabase>
Then it would end up creating schemas named SOME_NAME57 and SOME_NAME58 as the db is upgraded. Since we have to be able to define a part of the schema name so we can have different schemas for each profile.
You know what? I totally apologize...you are absolutely right! :0 That's exactly what happened. Yikes!
