Full Version: ppa 53 tvheadend Problem
after installing all in ubuntu 11.10 minimal, i had an Problem after ppa 53 Update.
XBMC starts but tvheadend starts ~ 2 minutes later.
Quote:Oct 23 11:58:11 xbmc kernel: [ 18.354326] Bluetooth: Core ver 2.16
Oct 23 11:58:11 xbmc kernel: [ 18.354380] NET: Registered protocol family 31
Oct 23 11:58:11 xbmc kernel: [ 18.354384] Bluetooth: HCI device and connection manager initialized
Oct 23 11:58:11 xbmc kernel: [ 18.354389] Bluetooth: HCI socket layer initialized
Oct 23 11:58:11 xbmc kernel: [ 18.354393] Bluetooth: L2CAP socket layer initialized
Oct 23 11:58:11 xbmc kernel: [ 18.356380] Bluetooth: SCO socket layer initialized
Oct 23 11:58:11 xbmc kernel: [ 18.368538] Bluetooth: RFCOMM TTY layer initialized
Oct 23 11:58:11 xbmc kernel: [ 18.368549] Bluetooth: RFCOMM socket layer initialized
Oct 23 11:58:11 xbmc kernel: [ 18.368553] Bluetooth: RFCOMM ver 1.11
Oct 23 12:00:05 xbmc kernel: [ 132.029729] type=1400 audit(1319364005.369:8): apparmor="STATUS" operation="profile_load" name="/usr/sbin/tcpdump" pid=1608 comm="apparmor_parser"
Oct 23 12:00:05 xbmc kernel: [ 132.131055] type=1400 audit(1319364005.469:9): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=1607 comm="apparmor_parser"
Oct 23 12:00:05 xbmc kernel: [ 132.131190] type=1400 audit(1319364005.469:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1607 comm="apparmor_parser"
Oct 23 12:00:05 xbmc kernel: [ 132.131316] type=1400 audit(1319364005.469:11): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=1607 comm="apparmor_parser"
Oct 23 12:00:05 xbmc cron[1661]: (CRON) INFO (pidfile fd = 3)
Oct 23 12:00:05 xbmc cron[1676]: (CRON) STARTUP (fork ok)
Oct 23 12:00:05 xbmc cron[1676]: (CRON) INFO (Running @reboot jobs)
Oct 23 12:00:06 xbmc kernel: [ 132.791122] init: plymouth-stop pre-start process (1750) terminated with status 1
Oct 23 12:00:07 xbmc tvheadend[1706]: EPG: Injected 9578 event from disk database
Oct 23 12:00:07 xbmc tvheadend[1706]: dvr: Creating new configuration ''
Oct 23 12:00:07 xbmc tvheadend[1706]: dvr: Output directory for video recording is not yet configured for DVR configuration "". Defaulting to to "/home/hts". This can be changed from the web user interface.
Oct 23 12:00:07 xbmc tvheadend[1706]: CSA: Using SSE2 128bit parallel descrambling
Oct 23 12:00:07 xbmc tvheadend[1706]: START: HTS Tvheadend version 2.12.99~pulse-1 started, running as PID:1706 UID:106 GID:44, settings located in '/home/hts/.hts/tvheadend'
Oct 23 12:00:54 xbmc tvheadend[1706]: htsp: Got connection from 127.0.0.1
Oct 23 12:00:54 xbmc tvheadend[1706]: htsp: 127.0.0.1: Welcomed client software: XBMC Media Center
Oct 23 12:00:54 xbmc tvheadend[1706]: htsp: 127.0.0.1 [ XBMC Media Center ]: Identified as user xbmc
Oct 23 12:00:54 xbmc tvheadend[1706]: htsp: 127.0.0.1 [ xbmc | XBMC Media Center ]: Privileges raised
What is wrong ?
OK, solved my Problem by creating an startup script for tvheadend in:
/etc/xbmc/live.d/
