This is probably really dumb, but i am trying to set up a profile for my young son, i have sucessfully created the profile, however is there a way to stop sources being added, all of my content is on the same computer as XBMC (no network shares). I must be missing something obvious cos whats the point of having a restricted profile if he can add any source he wants?
You need to enable master mode then check the option "Lock Settings" that will also lock the "add source"
Hmm, i have enabled the master lock, and on the profile i have created for the boy in the profile prefernereces i have locked every option but the movies, and when i log into that profie i can still add sources....
Thanks for the help with this, it's driving me nuts, i have 2 profiles set up, The master user with the master code set up, and my sons profile is that how it should be?
ok found how it works now
As long as you have entered a lock code you can do the following from your profile you don't have to be in master mode as profiles are automatically locked as soon as you have entered a lock code
Go to profiles and highlight your sons profile and select enter your get a window with a bunch of preferences go to the bottom one named "Media Sources" and scroll through them until you find "Separate Locked" that's all you need to do after that there won't be a add source option in your sons profile
This might help not the best quality but your get the picture
http://www.youtube.com/watch?v=1UIRlrUXFJY
man that was easy, thank you for all of your help with this......
