Hi everybody,
I try to compile a current git clone from xbmc with the libshaiport function enabled.
Before I tried to configure, I compiled the libshairport libraries like this
~/sources/github/xbmc$ cd lib/libshairport/
$ make
$ sudo make install
The installation seems to be fine
ls -al /usr/local/lib/
insgesamt 192
drwxr-xr-x 5 root root 4096 2011-10-25 18:50 .
drwxr-xr-x 10 root root 4096 2011-01-08 00:54 ..
-rwxr-xr-x 1 root root 972 2011-10-25 18:50 libshairport.la
lrwxrwxrwx 1 root root 21 2011-10-25 18:50 libshairport.so -> libshairport.so.0.0.0
lrwxrwxrwx 1 root root 21 2011-10-25 18:50 libshairport.so.0 -> libshairport.so.0.0.0
-rwxr-xr-x 1 root root 169696 2011-10-25 18:50 libshairport.so.0.0.0
drwxrwsr-x 4 root staff 4096 2011-10-15 14:02 python2.6
drwxrwsr-x 4 root staff 4096 2011-10-15 14:02 python2.7
drwxr-xr-x 4 root root 4096 2011-01-19 20:54 xbmc
To be sure, I did a 'ldconfig' manually.
But the configuring of xbmc fails with:
checking for main in -lplist... yes
checking for libplist soname... libplist.so.1
checking for shairport_set_ao in -lshairport... no
configure: error: == Could not find libshairport. AirTunes support disabled. =
Setting the LD_LIBRARY_PATH manually did not succeed :/
Am I missing something here? Thanks for your ideas
verify the headers are available for including:
ls /usr/local/include/shairport
also
ldconfig -v to verify creation of symbollic link to shared object
Hmm. IMO everything seems to be fine
$ ll /usr/local/include/shairport/
insgesamt 24
drwxr-xr-x 2 root root 4096 2011-10-31 00:54 ./
drwxr-xr-x 3 root root 4096 2011-10-19 21:18 ../
-rw-r--r-- 1 root root 6353 2011-10-31 00:54 ao.h
-rw-r--r-- 1 root root 1313 2011-10-31 00:54 shairport.h
-rw-r--r-- 1 root root 1088 2011-10-31 00:54 socketlib.h
as well as
sudo ldconfig -v
/usr/local/lib:
Any other ideas? I try to compile on Ubuntu 11.10
You installed to /usr/local. Try ./configure --prefix=/usr
Why don't use the delievered shairport sources?
You can use them with following commands (first change in the source folder of xbmc):
make -C lib/libshairport
make -C lib/libshairport install
Hi, did you solved the problem?
I am having the same issue.
Yes I have solved the problem.
I am not sure if you have to bootstrap again.
I ran the commands above and after it to ensure that it works a clean, bootstrap and configure, before running make.
ok thanks. But that still didn't do it for me
configure still doesn't find the libshairport
Does the system build the library correct?
Had you uninstalled your self builed library?
yep, I think so:
sudo make -C lib/libshairport install
libtool: install: /usr/bin/install -c .libs/libshairport.lai /usr/lib/libshairport.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin:/sbin" ldconfig -n /usr/lib
Libraries have been installed in:
/usr/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
test -z "/usr/include/shairport" || /bin/mkdir -p "/usr/include/shairport"
/usr/bin/install -c -m 644 shairport.h ao.h socketlib.h '/usr/include/shairport'
make[3]: Leaving directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib/src'
make[2]: Leaving directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib/src'
make[2]: Entering directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib'
make[3]: Entering directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib'
make[2]: Leaving directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib'
make[1]: Leaving directory `/home/htpc/xbmcgit/xbmc/lib/libshairport/libshairport-1.2.0.20310_lib'
ldconfig
make: Leaving directory `/home/htpc/xbmcgit/xbmc/lib/libshairport'
ls -la /usr/lib/libsha*
-rwxr-xr-x 1 root root 966 2011-11-08 13:27 /usr/lib/libshairport.la
lrwxrwxrwx 1 root root 21 2011-11-08 13:27 /usr/lib/libshairport.so -> libshairport.so.0.0.0
lrwxrwxrwx 1 root root 21 2011-11-08 13:27 /usr/lib/libshairport.so.0 -> libshairport.so.0.0.0
-rwxr-xr-x 1 root root 132107 2011-11-08 13:27 /usr/lib/libshairport.so.0.0.0
ls /usr/include/shairport/
ao.h shairport.h socketlib.h
/usr/lib/
After that bootstrap and configure?
yep, configure can't find libshairport
The custom build did you uninstall?
I deleted every files related to shairport in /use/local. Is this what you meant?
