Full Version: TV Episode Info View in Aeon MQ3
Newbie here and asolutely having a BLAST with XBMC (Dharma) and Aeon MQ3. Not sure if this is possible with a little XML editing or not, but I figure the experts here could at least lead me in the right direction. I've gotten everything setup the way I want it, but the info view in the tv episode screen (banner) bugs me.
When in the episode view (banner style):
After pressing "I" for info view I get the following screen:
Is there anyway to replace the episode picture with the season poster picture like this:
The low res graphics just don't look very good on a 55" screen.
Thanks in advance!!
+1
Smile
anyone?
+2
I think the only way you will be able to do this at the moment is manually.
Select get thumb and then use the art you want but this would take ages to do
Unfortuately that would also alter the Episode Art in the earlier view, so that doesn't help me. Although I appreciate the suggestion. I'm no expert in XML but I've got to imagine that if I could find the right section of code, it would be as simple as replacing the epsiode art variable with the season poster art.
I'm just not that SMART!!!!!
....the quest continues.
I am looking for the same.
It would make MQ3 perfect.
