2011-10-26, 18:22
I've been having trouble with my library after setting up AFP shares to be able to edit metadata using ViMediaManager on OS X with my library located on my Ubuntu Box. The problem is that when browsing the shared folders using OS X, .AppleDouble folders are created which stops the scrapers from scraping without stopping (No results for .AppleDouble folders).
I've been trying to solve this using a script which cleans my folders from these files when doing an automated library update (I do this when a torrent has been completed). This is still a problem when restarting XBMC since it scans the folders without running the cleaning script first.
So I found a solution and thought I might share it for the next person having the same problem.
The solution I just found is to make the scrapers ignore the .AppleDouble files. To do this solution you must add a couple of lines to advancedsettings.xml (or create it if it doesn't exist.
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<audio>
<excludefromscan>
<regexp>\.AppleDouble</regexp>
</excludefromscan>
</audio>
<video>
<excludefromscan>
</excludefromscan>
</video>
</advancedsettings>
