Full Version: Try to built my first htpc. Please help!!!
I need some advised please.
1) at5iont-i deluxe( with psu) or at5iont-i
2) mini itx case need fan or no need fanHuh
3) mini itx case can put sata hdd and sata DVD .
4) which ddr3 ram is okHuh
5) at5iont-i deluxe psu is ok for my sata DVD, motherboard and sata hddHuh
6) how to I make htpc as silent as I canHuh Please advised.
Please help!!!
Many thanks
Ock00 Wrote:Hi,
Please help!!!
Many thanks
check my signature below for info on case and ram. to make it silent, you'll need silent case fan and SAPPHIRE Radeon HD 6450 1GB
If you're set on the AT5IONT-I, I should be able to answer most questions.
1) The deluxe has on-board wi-fi. I can't comment on the PSU as I don't have one; nor can I find much info on it. However, it is going to be quieter than any standard PSU you get with a case.
2) A fan is a must. You can't put a powerful machine in a small box with no fan and expect it to be happy. I have space in my case (where I took out the PSU after getting a PicoPSU) for a slow spinning 120mm fan.
3) Many. Quite a few seem to be similar to the case in my spec, which is plenty big enough for my system. Personal preference really.
4) Any cheap (branded) RAM should be fine. You don't need to splash out on mega fast stuff, nor do you need more than 4GB (2GB if you're using linux). Don't forget you need laptop (SO-DIMM) RAM for this board.
5) No idea, sorry. Can't seem to find any specs on it.
6) Get a 'green' HDD, most of them spin at 5400rpm and make barely any noise. Use one large, slow spinning fan to get air flowing while reducing turbulence.
Many thanks
