ok, here comes the full logging
first , i played the movie ( the best years of our lives ) in xbox hd, and then on smb share, no problem at all, then i tried playing movies on dvd-rom, at first i played another movie ( guess who's coming to dinner ) on the same dvd-r on dvd-rom, no problem playing, then i played the movie at issue ( the best years of our lives ), the movie cannot be played, system hanged.
but the movie can be played on dvd-rom using xbmp, but cannot be played on dvd-rom using xbmc.
17-04-2005 19:25:06 info mplayer play:f:\movie\the best years of our lives.(1946)\best.years.of.our.lives.dual.cd1.avi cachesize:256
17-04-2005 19:25:06 info cached subtitle best.years.of.our.lives.dual.cd1.srt->z:\subtitle.srt
17-04-2005 19:25:06 info playing subtitle stream: 2
17-04-2005 19:25:06 info flipping bi-directional subtitles disabled
17-04-2005 19:25:06 debug msg:enable mplayer osd
17-04-2005 19:25:06 debug msg:mplayer dev-cvs-050410-13:35 © 2000-2004 mplayer team
17-04-2005 19:25:06 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
family: 6, stepping: 10)
17-04-2005 19:25:06 debug msg:detected cache-line size is 32 bytes
17-04-2005 19:25:06 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
17-04-2005 19:25:06 debug msg:compiled for x86 cpu with extensions:
17-04-2005 19:25:06 debug msg: mmx
17-04-2005 19:25:06 debug msg: mmx2
17-04-2005 19:25:06 debug msg: sse
17-04-2005 19:25:06 debug msg:78 audio & 187 video codecs
17-04-2005 19:25:06 debug msg:mplayer_open_file(f:\movie\the best years of our lives.(1946)\best.years.of.our.lives.dual.cd1.avi)
17-04-2005 19:25:06 info stating file f:\movie\the best years of our lives.(1946)\best.years.of.our.lives.dual.cd1.avi.conf
17-04-2005 19:25:06 info stating file q:\system\players\mplayer\f:\movie\the best years of our lives.(1946)\best.years.of.our.lives.dual.cd1.avi.conf
17-04-2005 19:25:06 debug msg:playing f:\movie\the best years of our lives.(1946)\best.years.of.our.lives.dual.cd1.avi.
17-04-2005 19:25:06 debug msg:auto open z:\subtitle
cache fill: 0.00% (0 bytes)
17-04-2005 19:25:06 debug msg:ogg file format detected.
17-04-2005 19:25:06 debug msg:video: [dx50] 512x368 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
tarting lookup for subs
ub: detected subtitle file format: subviewer
17-04-2005 19:25:07 debug msg
ub: read 928 subtitles
17-04-2005 19:25:07 debug msg:.
17-04-2005 19:25:07 debug msg:global subsize: 3 - vobsub: -1, demux: 0, subs: 2
17-04-2005 19:25:07 debug msg:global subpos : 2
17-04-2005 19:25:07 debug msg:==========================================================================
17-04-2005 19:25:07 debug msg:opening audio decoder: [libvorbis] ogg/vorbis audio decoder
17-04-2005 19:25:07 debug msg:audio: 48000 hz, 2 ch, 16 bit (0x10), ratio: 10060->192000 (80.5 kbit)
elected audio codec: [vorbis] afm:libvorbis (oggvorbis audio decoder)
17-04-2005 19:25:07 debug msg:opening video decoder: [ffmpeg] ffmpeg's libavcodec codec family
elected video codec: [ffodivx] vfm:ffmpeg (ffmpeg mpeg-4)
17-04-2005 19:25:07 debug msg:checking audio filter chain for 48000hz/2ch/16bit -> 48000hz/6ch/16bit...
17-04-2005 19:25:07 debug msg:af_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
17-04-2005 19:25:07 debug msg:af_pre: 48000hz 2ch signed 16-bit (little-endian)
17-04-2005 19:25:07 debug msg:ao: [win32] 48000hz 2ch signed 16-bit (little-endian) (2 bps)
17-04-2005 19:25:07 debug msg:building audio filter chain for 48000hz/2ch/16bit -> 48000hz/2ch/16bit...
tarting playback...
17-04-2005 19:25:07 debug msg:mplayer_open_file(f:\movie\the best years of our lives.(1946)\best.years.of.our.lives.dual.cd1.avi) done 1.0000
17-04-2005 19:25:07 notice start led control
17-04-2005 19:25:07 notice dim lcd on playback
17-04-2005 19:25:07 info activating window id: 12005
17-04-2005 19:25:07 debug msg:vdec: vo config request - 512 x 368 (preferred csp: planar yv12)
17-04-2005 19:25:07 debug msg:vdec: using planar yv12 as output csp (no 0)
17-04-2005 19:25:07 debug msg:movie-aspect is 1.39:1 - prescaling to correct movie aspect.
17-04-2005 19:25:07 debug msg:vo: [directx] 512x368 => 512x368 planar yv12
17-04-2005 19:25:07 debug created yv12 texture 0
17-04-2005 19:25:07 debug created yuy2 textures
17-04-2005 19:25:17 debug msg:
17-04-2005 19:25:17 debug freeing fs segment @ 0x893f60
17-04-2005 19:25:17 debug setting resolution 4
17-04-2005 19:25:17 debug we set resolution 4
17-04-2005 19:25:17 notice start led control
17-04-2005 19:25:17 notice dim lcd on playback
17-04-2005 19:25:27 info mplayer play
mb://smb share/the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi cachesize:256
17-04-2005 19:25:27 info cached subtitle best.years.of.our.lives.dual.cd1.srt->z:\subtitle.srt
17-04-2005 19:25:27 debug initializing fs_seg..
17-04-2005 19:25:27 debug fs segment @ 0x893f60
17-04-2005 19:25:27 info playing subtitle stream: 2
17-04-2005 19:25:27 info flipping bi-directional subtitles disabled
17-04-2005 19:25:27 debug msg:enable mplayer osd
17-04-2005 19:25:27 debug msg:mplayer dev-cvs-050410-13:35 © 2000-2004 mplayer team
17-04-2005 19:25:27 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
17-04-2005 19:25:27 debug msg:detected cache-line size is 32 bytes
17-04-2005 19:25:27 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
17-04-2005 19:25:27 debug msg:compiled for x86 cpu with extensions:
17-04-2005 19:25:27 debug msg: mmx
17-04-2005 19:25:27 debug msg: mmx2
17-04-2005 19:25:27 debug msg: sse
17-04-2005 19:25:27 debug msg:78 audio & 187 video codecs
17-04-2005 19:25:27 debug msg:mplayer_open_file(smb://smb share/the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi)
17-04-2005 19:25:27 info stating file smb://smb share/the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi.conf
17-04-2005 19:25:27 info stating file q:\system\players\mplayer\best.years.of.our.lives.dual.cd1.avi.conf
17-04-2005 19:25:27 debug msg:playing smb://smb share/the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi.
17-04-2005 19:25:27 debug msg:auto open z:\subtitle
17-04-2005 19:25:27 debug msg:protocol
mb
17-04-2005 19:25:27 debug msg:use standard file for protocol
mb
17-04-2005 19:25:28 debug msg:ogg file format detected.
17-04-2005 19:25:28 debug msg:video: [dx50] 512x368 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
17-04-2005 19:25:28 debug msg:.
17-04-2005 19:25:28 debug msg:global subsize: 3 - vobsub: -1, demux: 0, subs: 2
17-04-2005 19:25:28 debug msg:global subpos : 2
17-04-2005 19:25:28 debug msg:==========================================================================
17-04-2005 19:25:28 debug msg:opening audio decoder: [libvorbis] ogg/vorbis audio decoder
17-04-2005 19:25:28 debug msg:audio: 48000 hz, 2 ch, 16 bit (0x10), ratio: 10060->192000 (80.5 kbit)
17-04-2005 19:25:28 debug msg:opening video decoder: [ffmpeg] ffmpeg's libavcodec codec family
17-04-2005 19:25:28 debug msg:checking audio filter chain for 48000hz/2ch/16bit -> 48000hz/6ch/16bit...
17-04-2005 19:25:28 debug msg:af_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
17-04-2005 19:25:28 debug msg:af_pre: 48000hz 2ch signed 16-bit (little-endian)
17-04-2005 19:25:28 debug msg:ao: [win32] 48000hz 2ch signed 16-bit (little-endian) (2 bps)
17-04-2005 19:25:28 debug msg:building audio filter chain for 48000hz/2ch/16bit -> 48000hz/2ch/16bit...
tarting playback...
17-04-2005 19:25:28 debug msg:mplayer_open_file(smb://smb share/the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi) done 1.0000
17-04-2005 19:25:28 notice start led control
17-04-2005 19:25:28 notice dim lcd on playback
17-04-2005 19:25:28 info activating window id: 12005
17-04-2005 19:25:28 debug msg:vdec: vo config request - 512 x 368 (preferred csp: planar yv12)
17-04-2005 19:25:28 debug msg:vdec: using planar yv12 as output csp (no 0)
17-04-2005 19:25:28 debug msg:movie-aspect is 1.39:1 - prescaling to correct movie aspect.
17-04-2005 19:25:28 debug msg:vo: [directx] 512x368 => 512x368 planar yv12
17-04-2005 19:25:28 debug created yv12 texture 0
17-04-2005 19:25:28 debug created yuy2 textures
17-04-2005 19:25:46 debug msg:
17-04-2005 19:25:46 debug freeing fs segment @ 0x893f60
17-04-2005 19:25:47 debug setting resolution 4
17-04-2005 19:25:47 debug we set resolution 4
17-04-2005 19:25:47 notice start led control
17-04-2005 19:25:47 notice dim lcd on playback
17-04-2005 19:25:58 info detecting dvd-rom media filesystem...
17-04-2005 19:25:59 info cd analysis report
17-04-2005 19:25:59 info ____
17-04-2005 19:25:59 info cd-rom with both udf and iso 9660 filesystem
17-04-2005 19:25:59 info iso 9660: 2049616 blocks, label `dvdrip_moviez '
17-04-2005 19:25:59 info udf: version 1.02
17-04-2005 19:25:59 info tracks overall:1; audio tracks:0; data tracks:1
17-04-2005 19:25:59 info using protocol iso9660://
17-04-2005 19:25:59 info disc label: dvdrip_moviez
17-04-2005 19:26:04 info mplayer play:iso9660://guess who's coming to dinner (1967)/gwctd.(1967).divx5.02-ac3.cd1.avi cachesize:256
17-04-2005 19:26:04 info cached subtitle gwctd.(1967).divx5.02-ac3.cd1.srt->z:\subtitle.srt
17-04-2005 19:26:04 debug initializing fs_seg..
17-04-2005 19:26:04 debug fs segment @ 0x946010
17-04-2005 19:26:05 info flipping bi-directional subtitles disabled
17-04-2005 19:26:05 debug msg:enable mplayer osd
17-04-2005 19:26:05 debug msg:mplayer dev-cvs-050410-13:35 © 2000-2004 mplayer team
17-04-2005 19:26:05 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
17-04-2005 19:26:05 debug msg:detected cache-line size is 32 bytes
17-04-2005 19:26:05 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
17-04-2005 19:26:05 debug msg:compiled for x86 cpu with extensions:
17-04-2005 19:26:05 debug msg: mmx
17-04-2005 19:26:05 debug msg: mmx2
17-04-2005 19:26:05 debug msg: sse
17-04-2005 19:26:05 debug msg:78 audio & 187 video codecs
17-04-2005 19:26:05 debug msg:mplayer_open_file(iso9660://guess who's coming to dinner (1967)/gwctd.(1967).divx5.02-ac3.cd1.avi)
17-04-2005 19:26:05 info stating file iso9660://guess who's coming to dinner (1967)/gwctd.(1967).divx5.02-ac3.cd1.avi.conf
17-04-2005 19:26:05 info stating file q:\system\players\mplayer\gwctd.(1967).divx5.02-ac3.cd1.avi.conf
17-04-2005 19:26:05 debug msg:playing iso9660://guess who's coming to dinner (1967)/gwctd.(1967).divx5.02-ac3.cd1.avi.
17-04-2005 19:26:05 debug msg:auto open z:\subtitle
17-04-2005 19:26:05 debug msg:protocol:iso9660
17-04-2005 19:26:05 debug msg:use standard file for protocol:iso9660
17-04-2005 19:26:05 debug msg:avi file format detected.
17-04-2005 19:26:06 debug msg:video: [dx50] 608x336 24bpp 23.976 fps 1410.4 kbps (172.2 kbyte/s)
17-04-2005 19:26:06 debug msg:clip info:
17-04-2005 19:26:06 debug msg: software: nandub v1.0rc2
ub: read 837 subtitles
17-04-2005 19:26:06 debug msg:.
17-04-2005 19:26:06 debug msg:global subsize: 1 - vobsub: -1, demux: -1, subs: 0
17-04-2005 19:26:06 debug msg:global subpos : 0
17-04-2005 19:26:06 debug msg:==========================================================================
17-04-2005 19:26:06 debug msg:opening audio decoder: [mp3lib] mpeg layer-2, layer-3
17-04-2005 19:26:06 debug msg:audio: 48000 hz, 2 ch, 16 bit (0x10), ratio: 4000->192000 (32.0 kbit)
elected audio codec: [mp3] afm:mp3lib (mp3lib mpeg layer-2, layer-3)
17-04-2005 19:26:06 debug msg:opening video decoder: [ffmpeg] ffmpeg's libavcodec codec family
17-04-2005 19:26:06 debug msg:checking audio filter chain for 48000hz/2ch/16bit -> 48000hz/6ch/16bit...
17-04-2005 19:26:06 debug msg:af_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
17-04-2005 19:26:06 debug msg:af_pre: 48000hz 2ch signed 16-bit (little-endian)
17-04-2005 19:26:06 debug msg:ao: [win32] 48000hz 2ch signed 16-bit (little-endian) (2 bps)
17-04-2005 19:26:06 debug msg:building audio filter chain for 48000hz/2ch/16bit -> 48000hz/2ch/16bit...
tarting playback...
17-04-2005 19:26:06 debug msg:mplayer_open_file(iso9660://guess who's coming to dinner (1967)/gwctd.(1967).divx5.02-ac3.cd1.avi) done 1.0000
17-04-2005 19:26:06 notice start led control
17-04-2005 19:26:06 notice dim lcd on playback
17-04-2005 19:26:06 info activating window id: 12005
17-04-2005 19:26:06 debug msg:vdec: vo config request - 608 x 336 (preferred csp: planar yv12)
17-04-2005 19:26:06 debug msg:vdec: using planar yv12 as output csp (no 0)
17-04-2005 19:26:06 debug msg:movie-aspect is 1.81:1 - prescaling to correct movie aspect.
17-04-2005 19:26:06 debug msg:vo: [directx] 608x336 => 608x336 planar yv12
17-04-2005 19:26:06 debug created yv12 texture 0
17-04-2005 19:26:06 debug created yuy2 textures
17-04-2005 19:26:13 debug msg:
17-04-2005 19:26:13 debug freeing fs segment @ 0x946010
17-04-2005 19:26:14 debug setting resolution 4
17-04-2005 19:26:14 debug we set resolution 4
17-04-2005 19:26:14 notice start led control
17-04-2005 19:26:14 notice dim lcd on playback
17-04-2005 19:26:16 info mplayer play:iso9660://the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi cachesize:256
17-04-2005 19:26:17 info cached subtitle best.years.of.our.lives.dual.cd1.srt->z:\subtitle.srt
17-04-2005 19:26:17 debug initializing fs_seg..
17-04-2005 19:26:17 debug fs segment @ 0xa60100
17-04-2005 19:26:17 info flipping bi-directional subtitles disabled
17-04-2005 19:26:17 debug msg:enable mplayer osd
17-04-2005 19:26:17 debug msg:mplayer dev-cvs-050410-13:35 © 2000-2004 mplayer team
17-04-2005 19:26:17 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
17-04-2005 19:26:17 debug msg:detected cache-line size is 32 bytes
17-04-2005 19:26:17 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
17-04-2005 19:26:17 debug msg:compiled for x86 cpu with extensions:
17-04-2005 19:26:17 debug msg: mmx
17-04-2005 19:26:17 debug msg: mmx2
17-04-2005 19:26:17 debug msg: sse
17-04-2005 19:26:17 debug msg:78 audio & 187 video codecs
17-04-2005 19:26:17 debug msg:mplayer_open_file(iso9660://the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi)
17-04-2005 19:26:17 info stating file iso9660://the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi.conf
17-04-2005 19:26:17 info stating file q:\system\players\mplayer\best.years.of.our.lives.dual.cd1.avi.conf
17-04-2005 19:26:17 debug msg:playing iso9660://the best years of our lives.(1946)/best.years.of.our.lives.dual.cd1.avi.
17-04-2005 19:26:17 debug msg:auto open z:\subtitle
17-04-2005 19:26:17 debug msg:protocol:iso9660
17-04-2005 19:26:17 debug msg:use standard file for protocol:iso9660
