Full Version: Home Menu Buttons
I'm sure this has been asked before but I have been unable to find it whilst carrying out a search.
The problem I have is that when I add custom buttons to the home screen, such as 'Documentaries' and 'Music Videos', the words appear to long to fit on the menu and instead scroll across when highlighted so that the entire word can be seen.
I personally don't like this because it looks untidy and makes the menu look cramped. Is there anyway around this?
You could look into the theme settings or perhaps the XML for the main screen to see if you can slightly widen the text box or reduce the font size a bit. I'm pretty sure this is fairly optimized by the skin and theme creators, though.
My suggestion is that you think of a better, shorter name, if possible. For instance "Documentaries" could be "Features" and "Music Videos" could be "Music Vids".
