Full Version: Streaming. hear audio. but no video
hey guys... i've just updated to xbmc4-10-2005, and i haven't updated in forever, infact i just found out about scripts.
anyhow, on all of my scripts that stream video (stupidvids, launch, game trailers ,etc, etc) they all work find... however when it finally streams the file i get no video but i can hear the audio crystal clear.
i've tried searching for someone who had similar problems and i haven't found anything yet. since this happens on all scripts i'm sure it is an easy fix that i am missing.
anyone got any ideas? thanks!
this has nothing to do with scripts.
something to do with your codecs i guess.
if you start a stream not using the script you will get the same result.
so i should reinstall all my codecs? i'll give it a try.
i second this problem. i copied all the codecs from a xbmx build where the video scripts work and it didnt fix anything.
when you updated xbmc did you delete the xbmc temp folders?
e:\udata\0face008
e:\tdata\0face008
enable showfreemem in xboxmediacenter.xml and write down the values when bad things happen, both before, during and after
