2011-11-01, 06:39
Hi everyone!
I'm enjoying my XBMC Live, installed on my hard disk.
After changing the address to my RSS feed, the famous error popped out:
...I really don't understand how a file can corrupt itself like this, but by the way I read some solutions on the net, but every solution involved the use of the GUI
The most used solution consists in renaming the profile folder, letting XBMC starting from scratch (creating a new profile folder, since it can't find my renamed folder), copying from this new folder the xml needed and then deleting the new folder and re-renaming the previous one...but my question is: where can I find the profile folder in XBMC? Or is there another way to resolve this problem? Thank you all in advance!
Quote:Error: RssFeeds.xml was either not found in the system, or does not contain parsable XML. try deleting it from your userdata folder and restartin...
