Full Version: [AppleTv1] Force reload of settings.xml
Hi All,
I need to rebuild my appletv 1 and i dont have the remote for it (dogs ate it.) I have been using the android app on my phone to control it up to now but after i rebuild it I wont be able to do this as this needs to be enabled via the options menu. If i edit the settings.xml to enable the remote how do i force XBMC to pick up the change in the settings.
Thanks in advance,
BandyOrc
Why don't you just backup current settings.xml and reimport after reinstall?
Also, you can use a USB keyboard to browse menus in Crystalbuntu
