Full Version: using a 2.5 ssd for my HTPC, have a question
Hi Everyone,
so a quick question. I ordered a 2.5 ssd for my htpc, but after ordering I realized I had a few questions.
What's the best way to mount these in standard matx cases? Do some cases come with a solution for this? or should I just get a 3.5 adapter?
and, how do I connect a 2.5 hdd? The standard pc data and power connectors probably aren't used right?
I would appreciate any pointers or help.
I used velcro and mounted it to the case.
yeah, use even double sided tape
and stick it anywhere you want lol
How to install a Solid State Drive SSD
Perfect thanks!
since there is no moving part and it generate no heat, you can stick it to anywhere w/ double sided tape-
bluray, you really had to show an OCZ drive? Tongue
eskro Wrote:bluray, you really had to show an OCZ drive? Tongue
i have one ocz ssd in one my htpc, and it's working great so far. if the price is right, i'll buy another one. i'm not afraid to show it off either!
