2011-11-02, 20:31
Alright, I have three related questions here. It ended up being more wordy than I thought it would be, sorry.
First, I use iTunes on my desktop to organize my music. I don't have an iPhone or iPod, but no other player does Smart Playlists as well as iTunes does, so that's what I'm using. It's using a library stored via samba on my local server.
Using iTunes allows me to spend a lot of time upfront organizing my music and setting up smart playlists, then simply rating songs, changing a song's genre or adding a tag in the comments field is all I need to do to keep those playlists up to date. This saves an immense amount of time for me personally.
I'm just curious as to how I would export these smart playlists on a regular basis to allow them to be read by XBMC. Listening to music through iTunes is fine for my desktop, but when my netbook is hooked up to the television it's not quite as nice, so I'd like to use XBMC. I'd like to have a daily copy of each playlist in my library available to XBMC.
Every playlist exporter I've used thus far breaks when music is saved on a server, probably because of relative vs. absolute paths. I'd like to hear about any alternatives you may know of that work under these circumstances.
Second question: Is there a way to run a playlist whenever there has been more than a minute or so of idle time? When I start a video it kills the current playlist (Usually the startup playlist), and when I am done, the playlist doesn't start up again afterwards. I don't want it to start up if I immediately go from the end of one video to navigating to another, but I do want it to start if the video finishes and nothing happens afterward for a minute.
And third question, sorry. If the above is possible, can I get it to also play when a video is paused for longer than a minute, and end when I press play again? I'd bet that I can only have one song or one video playing at a time and no more, so probably not, but better to ask. I would love to have this functionality, things often get paused when others enter the room and want to talk, and then I forget to resume for awhile.
