Full Version: mobilesubstrate
Hi all,
I get the following response after an apt-get update and apt-get upgrade
The following packages have been kept back:
  mobilesubstrate
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Any idea how to solve this?
My ATV2 runs 4.2.2 and the 30-10 nightly build
regards
Henk
I'm sorry, but this has nothing to do with XBMC... No
You might not want to do it (hard to know what the implications are) but "apt-get dist-upgrade" should force the held back packages to get installed.
emkay Wrote:I'm sorry, but this has nothing to do with XBMC... No
I think (not sure) that mobilesubstrate is a dependency for XBMC. mobilesubstrate is sort of a jailbreakers standard API/framework for safely hacking/hooking into iOS.
I did just update with the above mentioned command and it seem to work great. When I rebooted the unit I found an update for Nito-TV when entering the atv menu. Unsure whether thats a coincidence or not.
