2005-04-15, 02:26
hello all,
i'm new to xbmc, and loving it! :thumbsup:
i was reading some posts about aspect ratio, and i'm still trying to figure out what i'm doing wrong with one kind of transcoding.
firstly, if i rip a typical ntsc movie off a dvd, it ends up at 720x480, but the "real" aspect ratio should be 16:9. therefore, if the rendering display has square pixels (x dpi == y dpi), this image must be stretched to 853x480 to be displayed at the correct aspect ratio.
if i encode to mp4 (using xvid and ffmpeg) and keep the same size (720x480), when i run xbmc in stretch 16:9, i get exactly the correct aspect ratio. that is, it works!
now, the video is really letterboxed in the 720x480 res. if i crop the top and bottom, the video is actually 720x360. because the rip is from a production movie, the actual aspect ratio of the "movie strip" is about 2.38 - but i'll settle for 2.37 - which is 720 stretched to 853 x 360 = 2.37.
so, i crop out the top 60 and bottom 60 lines from my transcode to produce a 720x360 xvid mp4 file. since i was using ffmpeg, i selected the option -aspect 2.37. also, i needed to use virtualdubmod to add the ac3 audio track back into the stream, so the xvid output is using the avi container (ffmpeg switch -f avi).
when i play this 720x360 file in xbmc, it doesn't seem to "see" the -aspect 2.37 option i gave to ffmpeg. maybe that option doesn't properly set the right flags in the xvid header, or perhaps there's something fishy using an avi container instead of an mp4 container.
does anyone have any suggestion on how i can use ffmpeg's xvid transcoder and also properly tag the aspect ratio correctly to xbmc reads the tag and properly scales the video? for now, i'll just do them at 720x480 - cause that seems to work, but i'd prefer to have the video's the correct size without the letterboxing in the stream.
thanks,
bb.
thanks,
bb.
