Full Version: Hibernate computer using XBMC Android remote
Is this somehow possible? Instead of beeing able to turn off XBMC it would be much more practical if I could hibernate my system using my phone. So basically can I somehow use the Android remote to send commands to Window? Or is there some other way?
Thank you.
XBMC has an option to tell it what to do when you shut it down. By default it exits but you can set it to shut down the PC or hibernate IIRC.
I can boot (WoL) and shut my PC down using the android remote when I have XBMC on Smile
