(i'm sorry if this has been reported before. couldn't find a thread about this excact problem)
i have enabled both "adjust framerate" and "pal 60".
when i play a movie encoded in 23.95 fps the movie is played back in 25 fps, which is fine. but still xbmc changes the output to pal 60, which it shouldn't.
same here, worked like a charm few builds ago ...
btw, just noticed this in the changelog:
Quote: - 15-04-2005 fixed: adjust frame rate and pal60 clash on 25fps files.
i haven't had time to try it out yet but i just want to point out that i was talking about 23.95 fps files and not 25 fps files. the 25 fps files were fine
not trying to be pedantic here, but thougt it would be best to make sure
still fixed in cvs.. mplayer were reporting the stored fps of the media, instead of the actual what it was playingö. so it needed to be adjusted.
ahhh... isn't it typical. you fix one thing, another thing gets broken :lol:
after the update, when adjust framerate is enabled by default, it doesn't have any effect. i have to enable it manually after starting the movie.
only if the movie has been played before.
it's one of the things that is saved on a per-movie basis.
