2011-11-11, 11:23
I want to select multiple files in the "Now Playing" list and do some manipulation with the selection: delete the selected tracks (from the list, not from the storage media), move up/down.
I couldn't find any way to do it. I could find only how to delete tracks one by one by adding a section like this in ~/.xbmc/userdata/keymaps/keyboard.xml
<MyMusicPlaylist>
<keyboard>
<zero>Delete</zero>
</keyboard>
</MyMusicPlaylist>
If I add a line like this
<one>Highlight</one>
it doesn't seem to be working, it looks like the "Highlight" function is not implemented in the "now Playing" list.
Two more things:
- if I click on a song from "Playing Now" and there are duplicates, it looks like they are highlighted (if I click while pressing the shift key)
- if I type "m" I get the OSD controls. Is there any shortcut to go directly to the "Playing Now" list? It looks to me quite a handy functionality, otherwise I have to go back to Music -> context-menu -> now-playing which can be quite a long path.
Thank you all for the best media centere ever.
(using 10.1, confluence skin)
<MyMusicPlaylist>
<keyboard>
<zero>Delete</zero>
</keyboard>
</MyMusicPlaylist>
Two more things:
