2011-11-11, 19:00
2011-11-11, 19:22
unabatedshagie Wrote:Is there any way of easily changing the capitalization of all text in MQ 3 from all caps to title case?
Since all text is located in the strings.xml you could try and find some kind of xml parser/ or xml editor that alows for text replace.
2011-11-11, 19:55
I think it's easier to edit "font.xml" in the 720p folder...
This is just one time setting the "font_name = caps" to "font_name = title"
Or did i not get the point?
mm
mm
2011-11-16, 10:36
mad-max Wrote:I think it's easier to edit "font.xml" in the 720p folder...
mm
Thanks, I'll give that a try first.
2011-11-17, 18:52
unabatedshagie Wrote:Thanks, I'll give that a try first.
Did that work for you? Where do i find the "font.xml" file?
2011-11-18, 00:03
Just checked, seems like the fonts (well some of them anyway) are hard coded as uppercase, I would have to change the font used in order to not have it in caps.
