2011-11-12, 01:35
I recently bought an Acer Revo R3600 and I'm having some problems installing the XBMC Live software. I downloaded the XBMC Live Dharma I have used Unetbootin (using Ubuntu distribution and 10.1 live version) to load the Dharma 10.1 iso from XBMC.org onto a 16gB USB stick.
I am able to run XBMC Live from the boot menu when I turn it on, however I get a couple of errors before hand that may be clues to why is doesn't install when I try:
"acer-wmi: no or unsupported WMI interface, unable to load"
It then moves to a screen displaying at the top:
"Ubuntu 10.04.2 LTS XBMCLive tty1"
and asking for xbmc password and login. Once i use the default passwords XBMC will load and work okay (except no internet). I am able to load XBMC from the same USB stick no problems on my Dell Vostro 1710.
However, when I try and install it will go no further than the "Install System" option before explaining it had to stop because of an error (gives no clue as to why!)
I'm very new to this set-up and have been trying to follow instructions from the forums to no avail - any help would be greatly appreciated and I will give any more information necessary.
Thanks in advance!
Thanks in advance!
