Full Version: Disable looping/cycling in grouplist?
Hi!
Please consider this:
PHP Code:
<control type="grouplist" id="103">
orientation>vertical</orientation>
control type="button" id="1001">
label>my label</label>
control>
control type="button" id="1002">
control>
control type="button" id="1003">
control>
control
If the last item/button is focused and I press the down arrow key, by default I go back to the first item... instead I want to be stuck at the last button (if I keep "going down") and only be able to go back by one position at a time, by pressing the UP key.
How may I disable the looping/cycling behavior described above?
Many thanks,
Guido
Add <ondown>-</ondown> to your grouplist.
