2011-11-14, 07:45
2011-11-14, 10:31
You can see the time finished in the upper right hand corner just under the time.
2011-11-14, 17:47
Sranshaft Wrote:You can see the time finished in the upper right hand corner just under the time.
This doesn't happen with mine. All I have in the top right is the time, say of the week, date, and month.
2011-11-14, 18:14
After some more searching, I see that it's now integrated into the git. I tried downloading and installing the git version, but xbmc says it's not in the right file structure. How do you install it compared to a regular skin install (zip file through addons)?
2011-11-15, 01:04
Aye. Sorry, I should have said I was using the GIT version. To install it, simply unzip the file you download from GIT, open %appdata%\XBMC\addons in Explorer, and drop the unzipped folder in to that.
