2015-01-12, 14:07
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208
2015-01-14, 22:29
I haven't been keeping up to much with this thread but since moving to Kodi has there been any update to AD to use the XBMC/Kodi naming syntax, or is AD still looking for files without the media file name in them?
Just curious if this has been changed and I can stop making duplicate artwork files for all media or not yet.
2015-01-14, 23:43
What's changed with Kodi? None of my artwork has the movie name in the filename. It worked in Gotham and it still works in Kodi.
2015-01-15, 00:18
(2015-01-14, 23:43)Glorious1 Wrote: [ -> ]What's changed with Kodi? None of my artwork has the movie name in the filename. It worked in Gotham and it still works in Kodi.
SO AD still uses one naming syntax while Kodi uses another? I guess I don't understand why it can't be more uniform. If Kodi recognizes the artwork (or exports it at least) with the file name in the syntax is there a reason AD is set-up differently?
2015-01-15, 00:46
I guess I'm not sure what the issue is. Maybe because I don't use AD to download anything. I use a media manager to download all artwork and name it as I specify (without movie names), and just have to use AD to get the local files into the database (although it still says it's "downloading". So I never export artwork from Kodi. Maybe that's avoiding confusion that I never knew existed.
2015-01-15, 01:22
(2015-01-15, 00:46)Glorious1 Wrote: [ -> ]I guess I'm not sure what the issue is. Maybe because I don't use AD to download anything. I use a media manager to download all artwork and name it as I specify (without movie names), and just have to use AD to get the local files into the database (although it still says it's "downloading". So I never export artwork from Kodi. Maybe that's avoiding confusion that I never knew existed.
Likely. Last I checked AD used a simple naming syntax for every media file. Every movie uses logo.pgn for the clearlogo, for example. While XBMC/Kodi uses the file name in the syntax so every movie gets MOVIETITLE-clearlogo.png. and so on. This makes it much easier to sort your files if needed as they are each now specific to a certain movie rather than all being named the same.
When you download your extra art, through some media manager or using AD in Kodi, you use the AD syntax. When it's imported into Kodi and then you export your library to individual with artwork (which you should do incase something goes wrong, saves having to start your library all over from scratch) Kodi 'sometimes' exports the extra art but with the filename syntax.
Also, if you want to manually add any extra art through Kodi and not use the AD auto downloader/installer, you need to have the Kodi syntax artwork in the folder, otherwise it won't be seen. When you have a library that's really big running AD just for 1 new movie slows down the system because it scans everything. So again, 2 different syntaxs are needed meaning 2 versions of each file in the folder. It was a HUGE pain when I decided to start adding all the extra art to my library after it was well over 1200 movies.
Makes more sense to me to use the Kodi syntax but I'm not the developer of this add-on so I'm not sure if if can or why it can't. So in the mean time I still add 2 versions of each piece of art to my new movie folders. the disk space doesn't concern me but I'm just OCD enough to keep wanting it to be more 'clean'.
2015-01-15, 01:43
I may be completely wrong, because it's been a while, but I think support has been added for both. I can't find the post though. Might be worth testing on a single file maybe.
2015-01-15, 02:23
Just tested both ways, one doesn't recognize the syntax of the other. Bummer. Duplicate files it is!
2015-01-15, 13:44
Hi!
I have a problem with this addon, dunno why.
I just added 200 films, clicked on "artwork" and it did his job. But, in noone of them, took a single discArt, so i have to put them 1 by 1 manually, which is pretty annoying. Basically, takes everything (extrafanart, extrathumbs, logo, poster, etc etc...) but the discARt.
Anyone could guess where is the error? Thanks in advance!
2015-01-15, 17:02
(2015-01-15, 13:44)serpao Wrote: [ -> ]Anyone could guess where is the error?
We might not have to guess if you give more information. Where did you click on "artwork"? Did you go through all the Artwork Downloader settings before starting it? Specifically, did you enable discart? Are you asking AD to find and download the artwork from the internet, or do you have local art files you are importing?
2015-01-15, 22:30
(2015-01-11, 11:24)TRaSH Wrote: [ -> ]Read the OP (Opening Post) and check the part bugs.
Here is my log;
http://pastebin.com/sCywSvUt
(I still don't have any artwork, always says 0 found while I have plenty of series/movies.)
2015-01-16, 11:35
(2015-01-15, 17:02)Glorious1 Wrote: [ -> ](2015-01-15, 13:44)serpao Wrote: [ -> ]Anyone could guess where is the error?
I also have the same problem. I have all my collection and external hard drives and when I download request makes it perfectly but I just saved on the hard disk and the extrathumbs extrafanart folders but I do not download everything else (hdclearlogo, logo, disc, banner etc ... Instead the skin if displayed perfectly but I would not recorded to the hard disk. I have it set up so that I download all so I do not understand what could happen. When I start the program and I have no connected hard drive me start downloading all the information again and gets inside the addon folder in a temp folder. Someone can help me?
2015-01-21, 02:14
Good evening, first wanted to thank all the team that developed this fantastic application.
I have a problem with the art downloader addon since I've configured to take me POSTER, FANART, CLEARLOGO, CLEARTART, DISC of the individual folders for the LOCAL movies.
When I buy logo and automatic clearart from MQ5 skin gets me all local files unless the logo, that although the config of art downloader is disabled makes me a different logo that I have in the folder.
I hope I explained well, I tried to find solution to this problem but the translation from English to Spanish have problems.
Thank you very much and greetings
2015-01-22, 01:47
2015-01-24, 14:55
Hello i have a Problem withg download Artwork to SMB share.
I use Kodi 14 with Dsplayer and shednox Skin. My SMB Share is on a Windows Server2003 all Shares have acces to all and Admin and all Users on my Network. All have readwrite acces.
When i scrap a Movie is all fine, the scrapper find/write to DB and Download the Poster and Fanart to my SMB share in the Movie Dir.
When i user AW-Downloader for the rest of artwork eg Disc ... find the files, Download to Temp DIR but can not copy to SMB Movie Folder
in the log file i read the Folder have no write acces. But why can the scraper write on this Folders?
On the TVtunes Plugin is the same Problem.
How can i Fix the write acces.
when i add the user:pass@.... save kodi to Password.xml
with nfs i have not the Problem but i will use smb share to hide my share on the Network.
00:13:20 T:3600 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
00:13:20 T:3600 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<advancedsettings>
<loglevel hide="false">1</loglevel>
<splash>false</splash>
<pathsubstitution>
<substitute>
<from>special://profile/RssFeeds.xml</from>
<to>smb://192.168.178.100/Kodi_MCU$/RssFeeds.xml</to>
</substitute>
<substitute>
<from>special://profile/playlists/</from>
<to>smb://192.168.178.100/Kodi_MCU$/Playlist/</to>
</substitute>
<substitute>
<from>special://masterprofile/Thumbnails/</from>
<to>smb://192.168.178.100/Kodi_MCU$/Thumbnails/</to>
</substitute>
<substitute>
<from>special://masterprofile/addon_data</from>
<to>smb://192.168.178.100/Kodi_MCU$/addon_data/</to>
</substitute>
<substitute>
<from>special://profile/sources.xml</from>
<to>smb://192.168.178.100/Kodi_MCU$/sources.xml</to>
</substitute>
</pathsubstitution>
<videodatabase>
<type>mysql</type>
<host>192.168.178.100</host>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
</videolibrary>
<video>
<!-- VideoExtras: Section Start -->
<excludefromscan action="append">
<regexp>/Extras/</regexp>
<regexp>[\\/]Extras[\\/]</regexp>
</excludefromscan>
<excludetvshowsfromscan action="append">
</excludetvshowsfromscan>
<!-- VideoExtras: Section End -->
</video>
</advancedsettings>
00:13:20 T:3600 NOTICE: Log level changed to "LOG_LEVEL_DEBUG"
00:13:21 T:3600 DEBUG: Configuring path substitutions
00:13:21 T:3600 DEBUG: Registering substition pair:
00:13:21 T:3600 DEBUG: From: [C:\Users\Nightchild\AppData\Roaming\Kodi\userdata\RssFeeds.xml]
00:13:21 T:3600 DEBUG: To: [smb://192.168.178.100/Kodi_MCU$/RssFeeds.xml]
00:13:21 T:3600 DEBUG: From: [C:\Users\Nightchild\AppData\Roaming\Kodi\userdata\playlists\]
00:13:21 T:3600 DEBUG: To: [smb://192.168.178.100/Kodi_MCU$/Playlist/]
00:13:21 T:3600 DEBUG: From: [C:\Users\Nightchild\AppData\Roaming\Kodi\userdata\Thumbnails\]
00:13:21 T:3600 DEBUG: To: [smb://192.168.178.100/Kodi_MCU$/Thumbnails/]
00:13:21 T:3600 DEBUG: From: [C:\Users\Nightchild\AppData\Roaming\Kodi\userdata\addon_data]
00:13:21 T:3600 DEBUG: To: [smb://192.168.178.100/Kodi_MCU$/addon_data/]
00:13:21 T:3600 WARNING: VIDEO database configuration is experimental.
00:13:21 T:3600 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
00:13:21 T:3600 NOTICE: Default DVD Player: dvdplayer
00:13:21 T:3600 NOTICE: Default Video Player: dvdplayer
00:13:21 T:3600 NOTICE: Default Audio Player: paplayer
13:51:33 T:5576 INFO: initializing python engine.
13:51:33 T:5576 DEBUG: CPythonInvoker(66, C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py): start processing
13:51:33 T:3600 DEBUG: ------ Window Deinit (custom_1119_ExtrasDialog.xml) ------
13:51:33 T:5576 NOTICE: -->Python Interpreter Initialized<--
13:51:33 T:5576 DEBUG: CPythonInvoker(66, C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py): the source file to load is "C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py"
13:51:33 T:5576 DEBUG: CPythonInvoker(66, C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py): setting the Python path to C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader;C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.common.plugin.cache\lib;C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.module.simplejson\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
13:51:33 T:5576 DEBUG: CPythonInvoker(66, C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py): entering source directory C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader
13:51:33 T:5576 DEBUG: CPythonInvoker(66, C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\default.py): instantiating addon using automatically obtained id of "script.artwork.downloader" dependent on version 2.1.0 of the xbmc.python api
13:51:33 T:5576 DEBUG: XFILE::CWin32SMBDirectory::ConnectAndAuthenticate: Connected to "\\192.168.178.100\Kodi_MCU$" with username "Administrator" and with password
13:51:34 T:5576 DEBUG: POParser: loaded 99 strings from file C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\resources\language\German\strings.po
13:51:34 T:5576 DEBUG: POParser: loaded 1 strings from file C:\Users\Nightchild\AppData\Roaming\Kodi\addons\script.artwork.downloader\resources\language\English\strings.po
13:51:34 T:5576 NOTICE: Artwork Downloader: ######## Artwork Downloader: Initializing...............................
13:51:34 T:5576 NOTICE: Artwork Downloader: ## Add-on Name = Artwork Downloader
13:51:34 T:5576 NOTICE: Artwork Downloader: ## Version = 12.0.29
13:51:34 T:5576 DEBUG: Artwork Downloader: ## Checking for downloading mode...
13:51:34 T:5576 DEBUG: Artwork Downloader: Setting up fileops
13:51:34 T:5576 DEBUG: Artwork Downloader: Using JSON for retrieving movie info
13:51:34 T:3600 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
13:51:34 T:5576 DEBUG: Artwork Downloader: ########################################################
13:51:34 T:5576 DEBUG: Artwork Downloader: Processing media: Appleseed Alpha
13:51:34 T:5576 DEBUG: Artwork Downloader: Provider ID: tt3638012
13:51:34 T:5576 DEBUG: Artwork Downloader: Media path: [u'smb://192.168.178.100/Filme$/Appleseed Alpha']
13:51:34 T:5576 DEBUG: Artwork Downloader: - Still missing some files
13:51:34 T:5576 DEBUG: Artwork Downloader: ['poster.jpg', 'fanart.jpg', 'extrafanart', 'extrathumbs', 'logo.png', 'clearart.png', 'disc.png', 'landscape.jpg', 'banner.jpg']
13:51:34 T:5576 DEBUG: Artwork Downloader: API: http://api.themoviedb.org/3/configuration?api_key=4be68d7eab1fbd1b6fd8a3b80a65a95e
13:51:35 T:5576 DEBUG: XFILE::CWin32SMBDirectory::ConnectAndAuthenticate: Connected to "\\192.168.178.100\Kodi_MCU$" with username "Administrator" and with password
13:51:35 T:5576 DEBUG: Artwork Downloader: API: http://api.themoviedb.org/3/movie/tt3638012/images?api_key=4be68d7eab1fbd1b6fd8a3b80a65a95e
13:51:35 T:5576 DEBUG: Artwork Downloader: API: http://webservice.fanart.tv/v3/movies/tt3638012?api_key=586118be1ac673f74963cc284d46bd8e
13:51:35 T:5576 DEBUG: Artwork Downloader: - Using GUI mode
13:51:35 T:3600 DEBUG: ------ Window Init (DialogSelect.xml) ------
13:51:35 T:3600 INFO: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
13:51:35 T:3600 WARNING: Trying to add unsupported control type 1
13:51:37 T:3600 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
13:51:37 T:3600 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
13:51:39 T:3600 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
13:51:39 T:3600 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
13:51:39 T:3600 DEBUG: ------ Window Deinit (DialogSelect.xml) ------
13:51:39 T:5576 DEBUG: Artwork Downloader: - Retrieving image list for GUI
13:51:39 T:5576 DEBUG: Artwork Downloader: - Image put to GUI: {'art_type': ['discart'], 'disctype': u'bluray', 'season': 'n/a', 'generalinfo': u'Language: English | Disc: 1 (bluray) | Votes: 3 | ', 'discnumber': u'1', 'id': u'76697', 'size': '', 'votes': 3, 'language': u'en', 'url': u'http://assets.fanart.tv/fanart/movies/269650/moviedisc/appleseed-alpha-53d3a706745ba.png', 'preview': u'http://assets.fanart.tv/fanart/movies/269650/moviedisc/appleseed-alpha-53d3a706745ba.png/preview'}
13:51:39 T:5576 DEBUG: Artwork Downloader: - Image put to GUI: {'art_type': ['discart'], 'disctype': u'bluray', 'season': 'n/a', 'generalinfo': u'Language: English | Disc: 1 (bluray) | Votes: 2 | ', 'discnumber': u'1', 'id': u'75692', 'size': '', 'votes': 2, 'language': u'en', 'url': u'http://assets.fanart.tv/fanart/movies/269650/moviedisc/appleseed-alpha-53c465d7933ce.png', 'preview': u'http://assets.fanart.tv/fanart/movies/269650/moviedisc/appleseed-alpha-53c465d7933ce.png/preview'}
13:51:39 T:3600 DEBUG: ------ Window Init (C:\Users\Nightchild\AppData\Roaming\Kodi\addons\skin.aeon.shednox.helix\1080i\DialogSelect.xml) ------
13:51:39 T:3600 INFO: Loading skin file: C:\Users\Nightchild\AppData\Roaming\Kodi\addons\skin.aeon.shednox.helix\1080i\DialogSelect.xml, load type: LOAD_ON_GUI_INIT
13:51:39 T:3600 WARNING: Trying to add unsupported control type 1
13:51:39 T:3600 DEBUG: CGUIMediaWindow::GetDirectory ()
13:51:39 T:3600 DEBUG: ParentPath = []
13:51:39 T:3600 ERROR: Control 6 in window 13000 has been asked to focus, but it can't
13:51:39 T:4784 ERROR: JSONRPC: Failed to parse '{"jsonrpc": "2.0", "method": "VideoLibrary.GetMovieDetails", "params": {"properties": ["streamdetails"], "movieid": }, "id": 1}'
13:51:39 T:4784 DEBUG: script.videolanguage: {"error":{"code":-32700,"message":"Parse error."},"id":null,"jsonrpc":"2.0"}
13:51:40 T:3600 DEBUG: ------ Window Init (Pointer.xml) ------
13:51:42 T:3600 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
13:51:45 T:3600 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
13:51:45 T:5576 DEBUG: Artwork Downloader: # GUI control: 6
13:51:45 T:5576 DEBUG: Artwork Downloader: # GUI position: 0
13:51:45 T:5576 DEBUG: Artwork Downloader: # GUI selected image ID: 76697
13:51:45 T:5576 DEBUG: DialogProgress::StartModal called
13:51:46 T:5576 DEBUG: ------ Window Init (DialogProgress.xml) ------
13:51:46 T:5576 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
13:51:46 T:5576 DEBUG: Artwork Downloader: * Image type: discart
13:51:46 T:3600 DEBUG: ------ Window Deinit (C:\Users\Nightchild\AppData\Roaming\Kodi\addons\skin.aeon.shednox.helix\1080i\DialogSelect.xml) ------
13:51:46 T:5576 DEBUG: Artwork Downloader: - Found a total of: 1 discart
13:51:46 T:5576 DEBUG: Artwork Downloader: ########################################################
13:51:46 T:4784 DEBUG: script.videolanguage: {"id":1,"jsonrpc":"2.0","result":{"moviedetails":{"label":"Appleseed Alpha","movieid":195,"streamdetails":{"audio":[{"channels":6,"codec":"dca","language":"ger"}],"subtitle":[{"language":"ger"},{"language":"ger"}],"video":[{"aspect":1.7777800559997559,"codec":"h264","duration":5595,"height":1080,"stereomode":"","width":1920}]}}}}
13:51:48 T:3600 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://rss.filmstarts.de (easy=05DEAB68, multi=0259A658)
13:51:50 T:3600 DEBUG: ------ Window Deinit (Pointer.xml) ------
13:52:09 T:5576 DEBUG: Artwork Downloader: [Appleseed Alpha] Downloaded: disc.png
13:52:09 T:5576 WARNING: Artwork Downloader: Could not copy file (Destination may be read only), skipping: u'smb://192.168.178.100/Filme$/Appleseed Alpha/disc.png'
13:52:09 T:5576 DEBUG: Artwork Downloader: Finished download
13:52:09 T:3600 DEBUG: ------ Window Init (DialogOK.xml) ------
13:52:09 T:3600 INFO: Loading skin file: DialogOK.xml, load type: KEEP_IN_MEMORY
13:52:09 T:5752 DEBUG: Thread JobWorker 5752 terminating (autodelete)
13:52:10 T:2120 DEBUG: Thread JobWorker 2120 terminating (autodelete)
13:52:10 T:2436 DEBUG: Thread JobWorker 2436 terminating (autodelete)
13:52:10 T:2692 DEBUG: Thread JobWorker 2692 terminating (autodelete)
13:52:15 T:3600 DEBUG: Keyboard: scancode: 0x38, sym: 0x0134, unicode: 0x0000, modifier: 0x100
13:52:15 T:3600 DEBUG: CApplication::OnKey: alt-leftalt (0x4f0d4) pressed, action is
13:52:15 T:3600 DEBUG: CWinEventsWin32::WndProcWindow is active
13:52:15 T:3600 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
