Ok guys, I hope I did this right...
I turned on debugging - And tried to use Artwork Downloader. Here's a link to "XBMC Log" that I got from %APPDATA%\XBMC\
I copy/pasted the info from "XBMC Log" into
http://xbmclogs.com.
If that's not correct then how may I do it proper?
Here's the log:
http://xbmclogs.com/show.php?id=6871
have Artwork Downloader a logfile where i could see which artwork i have get ?
Greets
Eisi
(2012-08-19, 19:51)Eisi2005 Wrote: [ -> ]Hi,
Greets
Eisi
Addon-Settings -> General -> View download report from latest download run
OK, I had weird issue running the script last night. Upon running, Artwork Downloader downloaded the same logo for almost 200 of my movies. The logo is shown below....
I don't know why that happened, but I'm curious if it happened to anyone else.
Yep had the same.
Should already be fixed.
Remove the logos and commancache.db
done. thx man. glad to know it's fixed.
XBMC -> Addons -> Artwork Downloader. Running it, will download images for all movies on library, great job, works fine to download extra thumbs/fanart.
Now try XBMC -> movie library -> movie info screen -> the artwork download in all skins I tried (confluence, aeon mq, xperience, etc.. each skin has a particular name for the artwork menu here) just offer a list of each available item to user select one. How I can change it to download all stuff for that movie in a batch (same as run addon "standalone" but for single movie)?
Someone understand my question?
I want this option because re-check all my library takes ~20 minutes when in reality I just want to get images for one or two movies...
(2012-08-22, 13:47)tinybutstrong Wrote: [ -> ]XBMC -> Addons -> Artwork Downloader. Running it, will download images for all movies on library, great job, works fine to download extra thumbs/fanart.
Only Aeon Nox has that feature that I know of. You could try changing this yourself if you know how to edit skins. See the first post to the wiki wich contains the example on how to do that
(2012-08-19, 00:19)Fennec Wrote: [ -> ]Ok guys, I hope I did this right...
I copy/pasted the info from "XBMC Log" into http://xbmclogs.com.
Here's the log: http://xbmclogs.com/show.php?id=6871
You also need to turn on debug in the add-on itself (prevent log spamming).
Besides that i can't see why it shouldn't work. It really has to be some write protect issues if you ask me
Hello
Having trouble downloading artwork for movies in RAR archive (the script works fine for tvshows in RAR archives, and movies that are not in RAR).
Here is
debug log.
(2012-08-22, 18:38)galfwender Wrote: [ -> ]Hello
Here is debug log.
enable debug in add-on settings to
(2012-08-22, 18:41)Martijn Wrote: [ -> ] (2012-08-22, 18:38)galfwender Wrote: [ -> ]Hello
Here is debug log.
It was already enabled but here is
another try
(2012-08-22, 19:01)galfwender Wrote: [ -> ] (2012-08-22, 18:41)Martijn Wrote: [ -> ] (2012-08-22, 18:38)galfwender Wrote: [ -> ]Hello
Here is debug log.
It was already enabled but here is another try
Nothing there. you need to enable XBMC debug
AND add-on debug.
Besides that rar files have been tested by a lot of people and it worked.
I still don't understand why people use it so don't expect me to put any effort in it (because imo rared video files are just pointless)
