Happy new year everyone!
Right now artwork downloader does not download any logo, clearart, cdart etc from fanart.tv. Is this just my problem or have they updated anything that has still to be fixed for the artworkdownloader app??
Running Frodo RC2 on Aeon Nox 4.0
i have the same problem today, after a reboot all was fine.
Think its a fanart.tv problem
Unfortunately that did not solve the problem for me. But thanks anyway
The Reboot solve the problem only for some time now the Problem is back
Hi all
I have noticed disc art images that are available on fanart.tv not showning up in artwork downloader when I select "get artwork" and "No" to "Do you want to download all available artwork without user interaction". I have ensured Disc Art is ticked under Artwork Downloader - Movies settings.
A couple of examples:
The Watch -
http://fanart.tv/movie/80035/the-watch/
The artwork found is Poster and Fanart but no disc art
Wedding Crashers -
http://fanart.tv/movie/9522/wedding-crashers/
I myself submitted the english disc art here but in Artwork Downloader, only the german cover is showing as available to download for disc art
My setup:
Aeon Nox 4.0
Frodo RC2
OSX Snow Leopard 10.6.8
Artwork Downloader Version: 12.0.12
Here is a debug log with debug enabled on the Artwork Downloader plugin also. I have used the 2 examples above during debug log capture
http://xbmclogs.com/show.php?id=25338
(2013-01-01, 21:34)diverseft Wrote: [ -> ]Hi all
The Watch - http://fanart.tv/movie/80035/the-watch/
Wedding Crashers - http://fanart.tv/movie/9522/wedding-crashers/
My setup:
Aeon Nox 4.0
Frodo RC2
On The Watch, the fanart.tv API timed out. It's right there in the log.
On Wedding Crashers, enough time hasn't elapsed for the discart to hit the API cache. Just wait another day or so and try again. If it still doesn't work, delete your commoncache.db from the userdata folder and try again.
Seems to be working.
I have got another question. How can i add cdart manually if artwork downloader does not show any to download eventhough there is one on fanart.tv?? Tried to put the cdart.png into the moviefolder but xbmc does not recognize it.
Using XBMC 12 Frodo RC2 with Aeon Nox 4
Edit: I have a folder in the xbmc appdata folder where the programm stores all the graphics but it seems to decrypt the filenames (e.g.: 3ae1398e.png). Anybody knows how i can integrate a new cdart in there?
Branphma
The file should be named disc.png, if you run AD from the movie info panel and select to download without user interaction it will pick up your local file and add it.
(2013-01-01, 23:24)thrak76 Wrote: [ -> ] (2013-01-01, 21:34)diverseft Wrote: [ -> ]Hi all
My setup:
Aeon Nox 4.0
Frodo RC2
Thanks thrak76. Will give that a shot and report back
Hey guys, i have a problem. I work with the actually nightly build of xbmc frodo and Aeon Nox 4.0 . I want for my movies the logoview. So i started with the AD. Works fine and he downloaded everything from fanart.tv. For some movies i created own logos, because there is nothing on fanart.tv. But some he takes, and some he really ignores.
Here is the Debug log:
http://pastebin.com/JrDqkrdk
I dont know what why he takes some and some not
(2013-01-02, 06:07)Kokonutcreme Wrote: [ -> ]Branphma
I placed the disc.png into the movie folder and into the appdata folder, but none of them is picked up by AD to be selected
Edit: I have read somewhere that AD would take the local file if i run it in bulk mode, but that did not work as well for me.
(2013-01-02, 11:07)barney stinsen Wrote: [ -> ]Hey guys, i have a problem. I work with the actually nightly build of xbmc frodo and Aeon Nox 4.0 . I want for my movies the logoview. So i started with the AD. Works fine and he downloaded everything from fanart.tv. For some movies i created own logos, because there is nothing on fanart.tv. But some he takes, and some he really ignores.
Here is the Debug log: http://pastebin.com/JrDqkrdk
Any suggestions to get the local art in the system? I´ve tried the last few days everything, but nothing helps. In the downloadreport shows the AD all movies, which get no art, only with artwork. The other have no logo found, no clearart found and so on.
Hello,
I have the problem that it takes a long time until the Clearart logos and CDArts be loaded at the movies from my NAS.
Is there a way to expedite this? Is it faster if I had to. Png files in the export folder on my NAS?
Is there a possibility that the Artwork Downloader automatically checks for new files when you update the library?
At present, one must always be updating the artwork downloader extra.
(2013-01-04, 13:57)Slipass Wrote: [ -> ]Hello,
i seem to be having the same issue esp with cdarts.. didn't think it would the the artwork downloader causing it?
The new method of xbmc frodo to fetch the images (posters, cleart, logo etc. ..) it goes by in a cache right?
If I change several posters with the metabrowser or ember and then delete the entire library and insert it again it will insert the old posters that had the cache, does not insert the new ... (that did not happen in Eden) but if I do manual reload a film he inserts the new poster.
Example: What if I change 200 posters in metabrowser'll have to reload manually one by one ..... to change in xbmc!
The only way I could insert the new posters is to do a fresh install of xbmc and so it will make a new cache and inserts the posters all correct
But there must be another way without having to install everything again
