See subject. The context menu only has "update library" in it under Videos, and if I go to Series or Movies, there's no add source button. Setting/Video doesn't have a link to it, either.
XBMC Pre-11.0 compiled Nov 12., Transparency v3.11.7
Redirected from
here.
Eklar Wrote:See subject. The context menu only has "update library" in it under Videos, and if I go to Series or Movies, there's no add source button. Setting/Video doesn't have a link to it, either.
XBMX Pre-11.0 compiled Nov 12., Transparency v3.11.7
Redirected from here.
If you go to the "videos" main menu item it should say 'add videos' ( this menu item must be enabled in skin settings)
It's also possible you disabled "show add source buttons in file list".
This is located in: settings--> appearence--> file lists...
Machine-Sanctum Wrote:If you go to the "videos" main menu item it should say 'add videos' ( this menu item must be enabled in skin settings)
There's no "add videos" or "add source" or something like that in settings/skin settings/menu, under Video, Movies, or any other sub-heading.
"Show add source buttons in file list" is enabled in settings
ronie Wrote:v3.11.7 is for xbmc dharma,
it is not compatible with nightly builds of xbmc.
use the svn version of Transparency! instead:
http://forum.xbmc.org/showthread.php?tid=83643
I don't have or know what SVN is, and it looks complicated.
I wouldn't use a nightly build, but it fixes a bug in the stable version which doesn't give me LFE channel with certain files
I guess I'll just have to live with my current library structure until the stable version is patched.
