2012-05-02, 23:15
2012-05-04, 14:11
Tomorrow, new Glass version will reactivate Library Editor.
But, to avoid conflict with Moviesets addon, you will have to call Library Editor by submenu Edit on Movie menu :
This submenu entry will be available after a skin init or after manually editing submenu 10 for Movie menu (System > Skin > Custom menus) and add this command :
When browsing a movie, you just have to open left slide menu and click on XBMC Library Editor.
You don't have to edit submenu for TV Shows as Moviesets is only active for movies.
ActivateWindow(Videos,MovieTitles,return)
2012-05-09, 04:19
Hi.
I've installed the skiing using the add ons way in my openelec system.
After the installation the system got freeze and I'd to reset the system twice to get it alive again, under confluence skin, and all my saved preferences gone.
I don't recommend to install this skin.
2012-05-09, 06:34
There is a problem with every skin in repo passion since 4 days, every thing is right now, that's ok now.
2012-05-09, 08:17
@Halfway : I don't know how powerfull is your HTPC but on my small Atom N330, you have to wait 3 or 4 minutes after downloading Glass to let OpenELEC unzip and install Glass and dependencies.
Your issues can be due to the fact that you have reboot your HTPC will Glass installation was in progress,
If you have a test PC, please retry this wonderful skin
And as fmronan said, our repository server have some troubles since 4 days. Sorry guys to not warn you about that
2012-05-09, 12:09
Now our repository server is OK, I don't know if Glass can be upgraded as usual for thos who have Glass without textures and images.
Here is the way to force update :
- Edit addon.xml file from Glass folder. Under Windows 7, his location is :
C:\Users\<user>\AppData\Roaming\XBMC\addons\skin.glass.svn
- At line # 2, you have a parameter :
- It should be :
- As today's version is 0.9.33.168, you could set up parameter to :
- Restart XBMC and Glass should update automatically.
version=
version="0.9.33.168"
version="0.9.33.167"
2012-05-23, 03:07
I love this skin but sometimes when I play a file, I get no picture and only sound. Also, at startup I keep getting a Script Error for script.extramusicinfo
Any suggestions?
Any suggestions?
2012-05-23, 06:57
install
script.ExtraMusicInfo
2012-05-23, 08:01
(2012-05-23, 03:07)douggoodwin Wrote: [ -> ]I love this skin but sometimes when I play a file, I get no picture and only sound.If you play this file in other skin, it play fine ?
I think is more an encoding problem than a skin problem.
2012-05-26, 05:14
I've tried again, after a clean installation...
The same result, system freeze after about 20 minutes of the complete download of the skin, all preferences lost when I've to restart it.
This only happens to me with this skin, and I've already tried about a dozen.
I will never again try to install this skin.
2012-05-26, 08:53
So sad to read you, Halfway
I don't know what happens, did you have keep your xbmc.log file ?
If you are running Windows ou Linux, is very simple to backup your XBMC config and start a fresh one to do some tests :
On Windows 7, just rename :
to
C:\Users\<user>\AppData\Roaming\XBMC_OK
Then restart XBMC and C:\Users\<user>\AppData\Roaming\XBMC will be recreate with a fresh XBMC configuration.
Play with it and when you want to restore your configured XBMC :
- stop XBMC
- rename C:\Users\<user>\AppData\Roaming\XBMC to C:\Users\<user>\AppData\Roaming\XBMC_Test
- rename C:\Users\<user>\AppData\Roaming\XBMC_OK to C:\Users\<user>\AppData\Roaming\XBMC
- start XBMC
Skin can be installed from Passion-XBMC repository but also by downloading zip :
http://passion-xbmc.org/addons/Download....33.168.zip
and install from ZIP file from XBMC menus.
EDIT : Passion-XBMC need to be installed even with ZIP installation
to
- stop XBMC
- start XBMC
2012-05-29, 08:03
(2012-05-23, 08:01)mikebzh44 Wrote: [ -> ](2012-05-23, 03:07)douggoodwin Wrote: [ -> ]I love this skin but sometimes when I play a file, I get no picture and only sound.If you play this file in other skin, it play fine ?
all files play fine in other skins
(2012-05-23, 06:57)fmronan Wrote: [ -> ]install
just did it. restarted and still get the same error
2012-05-29, 09:34
@douggoodwin :
* I don't think that Glass get a specific player so, for me, your playing problem is not related to Glass.
* Can you copy your log file to http://xbmclogs.com/? to see why script.ExtraMusicInfo did not work
@Judith271 : Are you talking about Glass skin ?
2012-06-06, 08:13
(2012-05-29, 09:34)mikebzh44 Wrote: [ -> ]@douggoodwin :
I just uploaded the log: http://xbmclogs.com/show.php?id=3294
Seems I moved the Music Video folder. Might explain some errors but not helping with the playback crashing. Lots of errors in there. If you can offer any insight, I would be grateful.
2012-06-06, 08:57
Yes, you have several ERROR with C:\Users\Home Theater\Videos\Music Videos\
Did you have make your own advancedsettings.xml because it seems to be not well formed :
22:05:21 T:5064 ERROR: Error loading special://profile/advancedsettings.xml, Line 15
Error reading end tag.
And you have errors with many addons :
script.sharethetv
webinterface.default
script.headlines
pvrchannelmanager
Is it a fresh install ?
script.sharethetv
script.headlines
pvrchannelmanager
