looks amazing mike, cant wait to try this. Plus Martijn's recent work on Artwork Downloader & fanart.tv site and your skin .!! great work . Thanks
It's not my skin but fmronan's one.
I'm only post on this forum because my english is a little bit better
And as fmronan said, if you are running Glass, you just have to install cine-passion repo then Glass.
mikebzh44
how could i change the ground color from the skin ? i don´t like the orange, my favorite is a grey or a blue-grey ? Is there any chance to change that ?
Greets
Eisi
Eisi, I will make you a little how to tomorrow morning
mike
thx
Greets
Eisi
fmronan
is there any chance to become a movie with bluray and dvd cases like aeon nox ?
Greets
Eisi
that's inside if you install glass: cases bluray and dvd and cdarts
there are many things like that in glass
add new entry with script global search ( by favorite) or a menu with ActivateWindow(1315) and you understand more
fmronan
hope we understand us right. I mean bluray cases like in screenshot
Greets
Eisi
Not exactly like that, you have differents cases
.avi, bd, divx, hddvd, mp4, vmv, mov etc
mike
you wrote that any view from other skin could use in glass with a little coding. If i want the case view from 2 posts before. What must i do to become this in glass ? And then it would nice to have cdart in there
I think it´s to haevy to make this ?
Greets
Eisi
If you want to make a view of Aeon Nox available in Glass, there is some coding to do.
fmronan did a how to but it's only in french and there is so many things to do and to understand that I won't be able to translate it to english
Eisi2005
fmronan will release a new custom view with case you like :
It will be my default view as I love those cases
(2012-03-21, 20:56)Eisi2005 Wrote: [ -> ]@mikebzh44
Greets
Eisi
To change the default colors, you have to go to System > Skin. On General settings tab, go bottom :
There is a translatation problem but fmronan will change labels soon.
So Fonts color let you choose your color for the specific element and Settings let you choose the transparency level
Color edit is provide by XBMC color picker from FrostBox (installed by default if you used Passion-XBMC repository to install Glass).
Mouse is very usefull to choose color
To set up transparency, just use the slider ()top of the screen).
Eisi2005 : New custom view added with cases you like
Install it from graphic installer (menu System submenu Views)
Then restart XBMC an go to System > Skin, tab "Views activate / deactivate" and activate custom view.
(I think there is a little translation problem, should be enable / disable
mike
great many many thx.
I have two litte problems again with the skin.
First in the new view from you all 720p movies become a "HDTV" case, but i want a BluRay Case. The 1080p movies become a BluRay case, where coulkd i finde the source to copy the 1080p for 720p.
And second i have problem with the german ratings. I become no rating or sometimes english rating. In my nfo files for movies i have <mpaa>16</mpaa> and <certification>Germany:16</certification>
Could i change that in the skin ?
Greets
Eisi
