Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
i use aeon nox, there is all good.
Greets
Eisi
ok, but that's not the right way.
I try to make the same thing for you tommorow
Can you make a screenshot with aeon nox please?
get time, for the rest all works fine !!
Thanks for your work
Greets
Eisi
No problem, I have found
Loving the amount of customization in this skin! Being able to use widgets derived from a playlist on the home screen is a feature I've been really wanting for in XBMC for a while now, so thank you!
Would it be possible to add a rightlistview? Or can someone point me in the right direction to take it from another skin so that it can be implemented in Glass?
Could you tell us with skin provide RightList View and post a screenshot ?
smush420 : fmronan already got his view in is old skin Influence. He will adapt and improve it to Glass shortly.
RightList Added MovieSet supported
German Flags added Too (tommorrow in next rev)
Great thanks! How would one add their own views? It would be great if all the users of this skin could contribute to this amazing feature.
I believe I found a small bug as well. If you have a custom playlist widget enable on the homescreen and are using the vertical layout, when you browse over to the widget you cannot leave it without playing something.
Adapting views from other skins to Glass is possible but need some coding skill.
fmronan did a How-To on our french forum but there is so many things to do and to understand, and some skins are more complex than other, than it will take time to translate it ton english
For the bug is in any menu? 1,2,3,4 or film, movies?
With movie playlist or tvshow inside?
I have a custom playlist widget for TV shows, which is the one with the bug
When you navigate to the Recently Aired widget is when the bug occurs.
Ok , i know why, you have some information with nextaIred widget?
Yes I have tv show next aired enabled and home next aired disabled
I speak a little french and tried reading the guide for adding views, but it's a little too complex for my basic french lol.
Ok , I fixed that and I know that's not easy with custom views.
