hello,
I couldn't make the "no fanart" works in tv show...and also could this option be available for the whole skin?
And IMO their not enough view for advance launcher...some poster views would be great!
thanks!
great work
cheers
Maybe that Passion-XBMC server was quite busy when you've tried.
Could you retry now ?
For me, at the moment, Glass is downloading but very slow (2 or 3 seconds per %).
You can also download ZIP form this address :
http://passion-xbmc.org/addons/Download....15.142.zip
And install ZIP in XBMC like you've install Passion-XBMC repository.
For fresh installation of Glass, we have some problems with dependancies since Passion-XBMC repository have change some version number.
Please wait until this problem is solved.
If you want to have video cases, according to movie resolution, displayed in widgets and movie info on Home as on this screenshot :
You have to enable this option in System > Skin > General Settings
If you do not want to have case for movieset because you use your own one like me :
You have to enable option Hide saga case (translation problem, should be Hide movieset case) on the left popup menu (up arrow then Misc options when displaying movies with Glass Resolution Case sutom view.
Hiya downloading now,.skin looks good will give it a whirl. cheers.
PS: cases option is a nice touch.
Ok,.now waiting for dependencies fix.
(2012-03-30, 08:16)bakito Wrote: [ -> ]hello,
thanks!
great work
cheers
Bakito.
You can have a new Custom View for Advance Launcher :
PS : Are you French, as your signature is
http://studio40.free.fr/ ?
Tu peux nous rejoindre sur le forum français :
http://passion-xbmc.org/glass/
With version 0.9.20.150, you can install Glass by different way :
1 - Unzip skin
Download ZIP skin :
http://passion-xbmc.org/addons/?Page=Vie....glass.svn
Unzip it in addon directory
Change XBMC skin to Glass
Go back to Home menu and press Init skin
It's the minimal installation as no other scripts are installed
To install more scripts, depending on your needs, you go to :
System > Settings > Addons
Press left arrow to display side menu
Clic on Skin dependencies
You can install all the dependencies or only some of them (one by one) :
2 - By Passion-XBMC repository
Download and install Passion-XBMC repository :
http://passion-xbmc.org/addons/?Page=Vie...n.xbmc.org
Install Glass : System > Settings > Addons > Download addons > Passion-XBMC > Skin > Glass
Glass will be installed with only minimal scripts.
To install other scripts, use the same menu as above.
I really like the full customization that allow your skin!
I try the advanced launcher view you tell me about but..well I still don't like it...
if you could add the xperience 1080 poster views ( the most beautiful poster view imo, especially the search view...)
that would be great!
anyway,great work!!
cheers!!
et oui je suis français
Hello,
I've a big problem. I installed this skin and changed the menu style to Carousel. But no the main menu disappeared. The screen shows only the weather and I´m nota able to reach the settings to change the menu style.
What can I do?
rgs
Stefan
