2005-04-18, 01:53
i'm running a 2005-04-16 build of xbmc. last changelog record is, "16-04-2005 fixed: audioscrobbler status was only updated when restarting after settings change".
i have 2 different avi files:
1) a 2.6gb ffmpeg-generated xvid .avi with ac3 audio.
2) a 2.1gb virtualdub/xvid codec-generated xvid .avi with ac3 audio.
the first one works fine, and i can ff/rw it using the triggers. the second one generates a message, "unable to ff/rw this stream".
i'm not sure why this stream can't be ff/rw, but the first one can. i thought it was a 2gb issue, but the first stream is bigger than 2gb and works flawlessly. or perhaps that's a fluke.
i'm going to try setting different xvid compressor options, but is there any option that i should set or not set that might be preventing xbmc from being able to ff/rw the stream?
thanks!
bb.
thanks!
bb.
