Full Version: problem to install xbmc whith putty
hey i tride to install xbmc whit "putty" but i have problem in the final stage:
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a s olution).
Apple-TV:~ root# apt-get -f install
Reading package lists... Done
Building dependency tree... Done
Correcting dependencies... Done
The following extra packages will be installed:
beigelist bsdiff gawk org.xbmc.xbmc-seatbeltunlock
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 0 to remove and 11 not upgraded.
1 not fully installed or removed.
Need to get 440kB of archives.
After this operation, 1368kB of additional disk space will be used.
Do you want to continue [Y/n]?
Abort.
I marked yes and no, but I still could not install the software after several attempts I gave up, is there something I'm doing it wrong? , Did you had a problem similar to this? , And whether their success to solve it?
Thanks in advance
