2012-04-18, 16:20
2012-06-17, 05:31
Just an update i have tried the animated background on my ATV2 and its only showing 2 FPS so looks bad :-( everything else is working great though :-)
2012-06-17, 08:35
In library mode, file list - background pictures are very bad visible. How can I change transparency of the skin?
Alda
Alda
2012-06-17, 14:34
(2012-06-17, 05:31)Ram2000 Wrote: [ -> ]Just an update i have tried the animated background on my ATV2 and its only showing 2 FPS so looks bad :-( everything else is working great though :-)
I think atv2 is not enough powerful for animated backgrounds.
Animated backgrounds are just pictures at a very high frame rate.
w2w
(2012-06-17, 08:35)alda Wrote: [ -> ]In library mode, file list - background pictures are very bad visible. How can I change transparency of the skin?
Alda
Please take and post a screenshot
2012-06-18, 13:11
The 2.7.3 download (http://www.mediafire.com/?7o0tcb1h3w3sv3g) and the PS3 waves download (http://www.mediafire.com/?2c4lcl4s576qmmf) seem to be the complete same files.
2012-06-18, 15:31
(2012-06-18, 13:11)MasterPhW Wrote: [ -> ]The 2.7.3 download (http://www.mediafire.com/?7o0tcb1h3w3sv3g) and the PS3 waves download (http://www.mediafire.com/?2c4lcl4s576qmmf) seem to be the complete same files.
Link to ps3 waves has been changed see first post
2012-06-18, 18:18
Thanks for the fast fix!
2012-06-18, 23:04
skin.w2w.alaska.revisited.2.73.zip
dependencies not met
XBMCbuntu 10.10
XBMCbuntu 10.10
2012-06-18, 23:51
Please read the first post before installation
2012-06-21, 16:12
w2w, thanks for your response. I got it loaded up ok and like what I see so far. I'm coming from Dharma Big Alaska and noticed two things missing:
1. I verified the RSS feed functionality on some other Skins but can't seem to figure out how to get it going here. Perhaps I have to reinstall.
2. Does the weather-temp in Alaska-R show up next to the clocktime like in Big Alaska?
TIA
TIA
2012-06-21, 16:41
This is very strange! Rss feeds and media totals are both on. I coded my mod in order to have media totals off if rss are on and vice versa.
So I understand wht you can't have rss feeds.
Copy and paste (and, yes replace!) .xml file in this archive (my mod folder->720p)
http://www.mediafire.com/?58peayxk47q44no
It should work
I don't know big Alaska but in your picture this is only time and date. Weather in the weather menu on home screen (go in skin settings to activate if not)
w2w
It should work
w2w
2012-06-29, 10:38
Hi from Spain,
Congratulations for your skin, it´s cool!,
I was wondering if you can help me to fix something:
I have added custom video addons items to the home menu.
Usually in other skins when you press back space it turn backs to the previous levels of the addon and finally to the home menu, but with yours the custom items it turns back to previous levels of the addon, then to the root (recently added, files, movies.....) and you have to press one more time backspace to get to the home menu.
Thanks in advance for your support!!1
2012-06-30, 08:35
The original skin is coded like that I can't help you.
In some other skins this is the same
w2w
w2w
2012-07-08, 08:18
2012-07-08, 09:54
Ok, I think it is coded like that.
You have to change this in xml.
This is not a bug
This is not a bug
