when I wake my pc from sleep I only get a black screened xbmc,I can hear the sound though...
I have to restart xbmc for things to get normal...any ideas?
I use one of the latest build ( like 18 november something like that...)
bakito Wrote:when I wake my pc from sleep I only get a black screened xbmc,I can hear the sound though...
it might help by selecting "balance or high perfromance" power option in windows 7 control panel and set hard drive to turn off 2 minutes before sleep in the advance power settings.
if that doesn't help, you try a couple more things below:
I. make sure that your video driver is update from here (
nvidia and
ati/amd)
II. Perform "Clean Boot"-
a. Click Start, type msconfig in the Start Search box, and then press ENTER.
b. On the General tab, click Selective Startup.
c. Under Selective Startup, click to clear the Load Startup Items check box.
d. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
e. Click OK.
f. When you are prompted, click Restart.
g. After the computer starts, check whether the problem is resolved.
good luck!
thanks I'll try that!
cheers
edit:euh pardon me but if I follow your instruction I'd be a bit worried about the results...
did this manipulation prevent all this stuff to load?
don't windows or my system needs it?
edit 2:well I did it anyway (though I left some stuff like antivirus,evenghost...) and it seems to work!
thanks!
