i am not able to enable zeroconf.
The option does not exist in Settings -> Network
look at the screenshot
I build with --enable-avahi and a zeroconf.o was also created.
Manually adding the string in the config file does not help, it will be deleted on restart of xbmc.
I am running XBMC PRE-11.0 Git:20111120-6228996 from opdenkamps master git on ubuntu 11.10 (arm-v7).
Anybody an idea how to enable it?
do you have libavahi-dev installed during configure and build?
don't have a package libavahi-dev available, but libavahi-common-dev and libavahi-client-dev
root@panda:~# dpkg -l | grep libavahi
ii libavahi-client-dev 0.6.30-4ubuntu1 Development files for the Avahi client library
ii libavahi-client3 0.6.30-4ubuntu1 Avahi client library
ii libavahi-common-data 0.6.30-4ubuntu1 Avahi common data files
ii libavahi-common-dev 0.6.30-4ubuntu1 Development files for the Avahi common library
ii libavahi-common3 0.6.30-4ubuntu1 Avahi common library
ii libavahi-compat-libdnssd1 0.6.30-4ubuntu1 Avahi Apple Bonjour compatibility library
ii libavahi-core7 0.6.30-4ubuntu1 Avahi's embeddable mDNS/DNS-SD library
ii libavahi-glib1 0.6.30-4ubuntu1 Avahi glib integration library
ii libavahi-gobject0 0.6.30-4ubuntu1 Avahi GObject library
ii libavahi-ui-gtk3-0 0.6.30-4ubuntu1 Avahi GTK+ User interface library for GTK3
ii libavahi-ui0 0.6.30-4ubuntu1 Avahi GTK+ User interface library
//EDIT: Configure displayed also that it will build with avahi
i tried to add manually the AirPlay and AirTunes services to avahi
via
<service>
<type>_airplay._tcp</type>
<port>36667</port>
</service>
<service>
<type>_raop._tcp</type>
<port>36666</port>
</service>
bonjour browser does me also show this up, but no idevice recognize the server. Do i miss something?
