Full Version: Screen Tears Mac Book Pro
Hi guys,
I have been having a slight issue with my XBMC setup.
For films there is no issue but when watching tv shows i see screen tears at the top of the screen (although they can also appear mid screen).
I have played around with all the playback options, i have the same issue when using my Mac screen as when i am using my TV.
My Mac
Processor 2.3 GHz Intel Core i5
Memory 4 GB 1333 MHz DDR3
Graphics Intel HD Graphics 3000 384 MB
Software Mac OS X Lion 10.7.2 (11C74)
I am using a nightly build of XBMC but had the same issues on Dhrama. I am using the reFocus skin but have also had a similar issues with other skins.
I am likely to be upgrading to a Mac Mini for XMBC but don't want to have a similar issue.
Does anyone know how to solve my current problem or if i am likely to see the same on a new setup using a mac?
xbmc.log or no soup Smile
Why did you disable vsync ? The default on XBMC for Mac is enabled.
"INFO: GL: Disabling VSYNC"
Without having xmbc in front of me, i assume this is turned off in the playback settings menu.
I was attempting to resolve the issue and played around with these options.
I think if i had that enabled then screen tears would appear more random and not so much concentrated to the top of the screen.
setting -> system -> video.
turn it on, leave it on. any video playback visual issues are unrelated to this setting.
Ahhh, I thought you were talking about av sync method. Cool, have turned it back on.
Anything else?
