I have a mac mini 2011.
I have 2 XBMC installed.
Xbmc installed in Osx lion and XBMC in Windows 7 by bootcamp.
- XBMC in MAC Os x lion : I can use Apple remote.
- XBMC in Windows 7 : I think Xbmc for windows better for Mac,dont I?
but in Windows I can not use Apple remote.
Help me choose 1 . please
someone help?
help me with the correct choice or fixed it.Please
I'm not sure what you're asking?
Are you asking how to make the Apple remote work in XBMC? If so I believe it can be done using a helper app like Eventghost.
I have a Mac Mini and I use Bootcamp and XBMC for Windows. I use a USB MCE remote instead of the Apple remote.
JR
stephenchow Wrote:I have a mac mini 2011.
Why do you think XBMC for Windows is better then XBMC for MacOSX? TBH I think the other way around
Thank you for reply.
When I play Xbmc nightly build for Os x lion, Very nice,perfect.
Because I use XBMC for windows is very very long time, so in my mind that XBMC is always number one. Xbmc better than Plex and other.... I use XBMC Ios for ATV 2 and I felt it could not be with XBMC for windows should I even think it's better than XBMC for Mac.
However Xbmc for Mac os lion can not support DTS-HD?
If you said Xbmc for Mac os is the same XBMC Windows. I will follow u.
So I tried to Fix my Apple remote many time by Evenghost, but I can't.
One again. Thank you for reply.
I love XBMc
they are the same, I don't think HD Audio Streams are supported at the moment on any platform (Audio Engine Branch Excluded).
Run on what your more comfortable using.
