2011-11-22, 20:03
2011-12-02, 03:51
running kinda slow when changing between menus and browsing media, decided against mq3 before even testing playback
i'm running the Nov 21st compiled version currently, will test again if i update the build version
2012-01-06, 10:36
I'm in the process of setting it up, and I must say I have it running pretty smoothly by now. There is some stuff you have to take into consideration. On the video library views make sure you disable fanart backgrounds (left menu), then the entire system will run pretty smooth. I'm now looking into some 'light' backgrounds for the rest...
UPDATE: everything is running smooth except changing of the menus unfortunately. I don't think this can be easily fixed, my guess is that is has to do with the 'huge' home.xml and includes.xml in comparison to Confluence, but I'm in no way a coder, so this could also be bs from my side :-)
