Full Version: [ATV2] - No Weather Option / Library In Nightly Build
Last night I installed XBMC on my Apple TV2 via Firecore aTV Flash but found that my library wouldn't contact the server to update information.
So I uninstalled and manually installed a nightly build and then it appears that the unit now connects to a server to update. The problem being now that no 'Library' option appears under Video (just Files and Add) and also there is no weather tab. I have used XBMC on a Windows box before and have been pleased with it. I have yet to get the same video library experience on a Apple TV2.
Any tips? Thanks.
For you weather question, check this thread:
http://forum.xbmc.org/showthread.php?tid...ht=weather
Make sure you have followed the correct procedure to install and update to nightly build. Read the FAQ.
You won't get any library functionality until you add something to it.
Create sources by going to Video->Files->Add source
Browse to the souce, press right arrow. Tell it if it is looking at movies or tv shows then update the library.
To right click on ATV2 press and hold menu on an item.
Look for tutorials on youtube to see how it is done.
