2011-11-23, 13:57
2011-11-23, 13:57
2011-11-23, 14:35
try renaming your files to NCIS Los Ageles S05EXX.avi where XX is the episode number
2011-11-23, 16:12
2011-11-23, 16:33
^^^ maybe here http://thetvdb.com/?tab=series&id=82083&lid=7 and no season 5 exists too.
2011-11-23, 17:25
djashjones & spiff, not sure why he'd rename 1000 Ways to Die to NCIS.
bckane congratulations, basically you have to figure out where the Scene and Spike TV differ and rename your TV shows accordingly.
So it looks like S05 is actually S03. I haven't seen an episode of American Dad yet because of an issue like this.
Scene is releasing S07. Wiki says we're on S07. FOX says we're on Season 08. TheTVDB (and like wise Sickbeard) are on Season 8.
If you want XBMC to pick up your stuff, you need to match TheTVDB.
S05E01 NZB Wrote:Yes this is technically s04, spike decided the first 2 eps
of the series werent a season callin them standalone eps, but it
makes more sense to keep goin with current labling.
2011-11-23, 19:29
djashjones Wrote:try renaming your files to NCIS Los Ageles S05EXX.avi where XX is the episode number
I don't have a problem with NCIS its the 1000 ways to die
ncis works fine
2011-11-23, 19:40
joethefox Wrote:^^^ maybe here http://thetvdb.com/?tab=series&id=82083&lid=7 and no season 5 exists too.
you nailed it no season 5.....its was season 3 and season 2
I remained them and all worked fine.......Thanks
