I've been searching for quite sometime about this and can't find an answer.
I use Ember and it stores all .tbn, .nfo etc in the file where the movie/tv show is. How can I be certain is XBMC is using the locally stored info?
For one the artwork will be identical to that you have chosen in ember
If you want to be certain turn on debug when you scan them into your library then it will be in your log, you know its only used once when you scan after that xbmc uses its database and artwork comes from its cache
If you use ember after items are in your library then you need to refresh each movie you change for the same reason I gave above
>>X<<' Wrote:For one the artwork will be identical to that you have chosen in ember
OK great, and where is this log stored?
I'm using openELEC, by the way.
