2011-11-24, 19:36
I have set up a mysql db and have xbmc on two computers (win7) and one appleTV2.
And I'm not really sure what settings are the best.
* I mean should all clients update the db at startup or just one dedicated?
* And should all clients "run automated scans"?
In the beginning I had some problems with multiple entries and other odd stuff - turned out that something had made errounous updates to the nfo-files. I'm not sure what part of the system to blame for that though, maybe the xbmc export or db update (sound weird that the update would change the .nfo files...) It could also be some other tool for nfo-updates.
Anyway. That have been sorted but one thing remains, If I let the appleTV do the updates, I get some odd duplicates, could be that the ATV interprets some " ' " (single comma) as different character than windows does...
What I really would like is some tool that updates the db without xbmc, is there one?
I use Sickbeard and CouchPotato but as I understand it, they both update through xbmc only.
And neither does Ember MediaManager.
Is there some tool for this or can any of the mentioned tools do this?
