i'm running a pre-eden of the 17th of november and i have a stupid problem starting audio and video stream.
after the startup of xbmc the first thing i play, starts without sound if i increase the volume the streem freez for about 10 seconds and than it re-start from the beginning in the right way (with the sound).
can someone help me?
peppe
A debug log might tell use what's happening. Enable debug logging from System settings, System, Debugging, and restart XBMC then wait a minute or two for all the startup tasks to finish. Play a video and try to increase the sound as you describe, then let the video play for 30 seconds or so. Stop the video and close XBMC.
Open the debug log by pressing Windows-R and in the Run dialog type:
"%appdata%\xbmc\xbmc.log"
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into
http://pastebin.com/ and post the link it gives you here.
JR
ok JR i'll do what you suggest, because today after i set on the debug logging the problem was not showed.
but i haven't waited as you said.
peppe
jhsrennie Wrote:Open the debug log by pressing Windows-R and in the Run dialog type:
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into http://pastebin.com/ and post the link it gives you here.
JR
i'm here again, i understand that the problem occurs only when i use the xbmc after the star-up of my pc.
her is the log with the freeze.
Quote:http://pastebin.com/SXweDhDg
in this sesion of xbmc:
i launch the video (una note da leoni 2) and it freezes after 10 second it starts.
i stopped the video, i started it again and it works good.
that's all
Hmm, that does look odd.
What are you using to control XBMC. It's not the keyboard or a remote that emulates the keyboard. Is it a remote control app on your phone?
JR
i'm using an old "xbox remote".
infos are here in 1st and 3rd post
http://forum.xbmc.org/showthread.php?tid=115408
could be the problem a corupt video file in the library?
i see in the log this:
ERROR: CDVDDemuxFFmpeg::Open - error probing input format, M:\Film\Dolans.Cadillac.2009.iTALiAN.DVDRip.XviD-TRL.avi
but i haven't touched that movie. thinking it was corrupted and i have deleted it. after the reboot (i did a couple of test) the system works.
what do you think about?
peppe
