[quote]At the bottom it shows the episode info. Is there a way to remove the text from below the "episode"/PPV? Or is there a way to put the name of the PPV there instead of this generic text?[\quote]
Just rename the folder to say "1. Royal Rumble 2013"? It doesn't have to be S29E01 for it to work.
Well, right now it won't read the nfo file for each ppv at all. It is forcing the nfo from the tvshow.nfo file into the info for each ppv. Until I can get it to start reading the ppv nfo again, i don't want to start renaming things.
(2013-08-03, 17:09)exoscoriae Wrote: [ -> ]Well, right now it won't read the nfo file for each ppv at all. It is forcing the nfo from the tvshow.nfo file into the info for each ppv. Until I can get it to start reading the ppv nfo again, i don't want to start renaming things.
Is the nfo file named exactly the same as the video file?
yes. Just 2 posts back on the previous page I had posted my file setup and naming. Here it is again for reference:
Season 01
-S01E01
--S01E01.AVI
--S01E01.NFO
-S01E02
--S01E02.AVI
--S01E02.NFO
each dash represents a sub folder
Essentially, it appears to be ignoring these nfo files and just reading the tcshow.nfo file and applying that data to all of the movie files.
Whats odd though, is it sees the video files just fine AND it sees all the artwork in those folders just fine. So I know it is scanning and seeing the video files and art - I just can't understand why it is skipping the nfo files.
here is a sample nfo file for an episode:
http://pastebin.com/W0X8Lr1E
and here is the tvshow.nfo file that it keeps reading:
http://pastebin.com/ixkpxh2h
EDIT:
It seems that after a lot of work, I was able to figure out the problem. A key portion of it being that it there was a misconception earlier that you could view the nfo for a ppv in file mode as long as you had scanned it in as a tv series. The truth is that it will show you an nfo file, but it derives it from the tvshow.nfo- not from the individual ppv (episode) nfo file.
So accessing nfo information via file mode is a bust. Looks like it is on to movie mode.
How do I name multi part files for example
WWE pay per view
Season 1-1985
S01E01 - Wrestlemania
Wrestlemania cd1.avi
Wrestlemania cd2.avi
It's the 2 avi files I'm wondering about so xbmc will recognize them both
Thanks very much
All WWE events have pretty much now been added to the site thanks to a few dedicated editors. They have added posters and loads of other information including results.
Using the dedicated sports scraper above you can now scan in the entire WWE back catalogue.
Happy days!
And what it looks like inside Kodi
Just working to get 1999 to 2010 added but hopefully they'll be there in the next couple of weeks.
After that any chance you could add WCW, ECW, RoH sections? I'm happy to take responsibility for those too.
Full UFC historical events added, all the way back to the 1993 UFC 1 event! Thanks to n1md4 for compiling the data!
Now we just need the artwork, description and results for all those events
http://www.thesportsdb.com/league/4443
(2016-01-30, 17:50)Aaskari1988 Wrote: [ -> ]so i wanna add all raw episodes to kodi sorted by year.
i have 95,96 and so on. can this get data for all Raw episodes?
Only main events work at the moment as thats all thats been added to TheSportsDB.
Since its a user contribution database you could potentially add those events, but it might be hard to find artwork for them.
Example 2015 WWE main events -
http://www.thesportsdb.com/season.php?l=4444&s=2015
