2011-11-27, 03:32
Hello All!
So I made a change to my system which has left one of the XBMC machines unable to login.
I used to have a NAS (DNS-323) but it only had 1 TB and even though I know I could have upgraded the drives to 2 TB it was only 2 drives and I wanted to have a little more data security. So I decided to install 4 500GB Seagate Barracuda drives in RAID5 on my Windows 7 machine since it's on ALL the time anyway.
After moving over all the files I had to go through all the XBMC installs and change the file location to the RAID. My ATV2's and iPAD both worked without a hitch. The XBMC Live on my HTPC didn't work.
I have tried removing myself from the homegroup and ensuring the advanced options are as required. I do not have Windows Live Sign In Assistant installed either.
The guides i've found online are fairly old and I would imagine there has to be something I'm missing but I have made sure that the password i'm using it correct.
I have another computer which I plan to use as my HTPC. It's a Core 2 Quad Q9450 with 4 GB of RAM and a GeForce 9800 GTX video card which I'll use a DVI to HDMI cable on. Would it be ok to run XBMC from Windows 7 or should I do the same as my existing HTPC and have a dual boot? I had XBMC running from Windows on that machine before and it was really quick.
Thanks in advance!
Thanks in advance!
