2011-11-27, 14:24
2011-11-27, 15:39
yes, you can modify DialogButtonMenu.xml
it's in the 720p folder of the skin you"re using.
just keep mind any modifications will be wiped when the skin is updated.
2011-11-27, 16:01
is there a wiki link which would help me understand the format?
2011-11-27, 16:18
there's an entire section devoted to skinning on our wiki:
http://wiki.xbmc.org/index.php?title=Skinning_Manual
that being said, the best way to get started is just look at the code,
try to somewhat understand the structure, make a few changes and check what happens on-screen.
2011-11-27, 16:33
2017-03-14, 07:16
I have a coding problem With Aeon nox silvo build. I have edited the exit menu to include Video addon window, and Program Addons, and File manager. I have done this on windows, but when I move the build to android. These sections don't show up on the menu. does anyone know what I am doing wrong.
